Pietenpol-List: Re: rudder/elev hinges
Posted: Wed Apr 14, 1999 3:42 am
Subject: Pietenpol-List: Re: rudder/elev hinges>I used eyebolts for elevator and rudder hinges. I spent a lot of effort>making sure that they wouldn't turn and lock up but, because they don'tshare>the same axis, they cannot turn, and, with three on each panel, they don't>lock up.>>Jim Malley>________________________________________________________________________________
Pietenpol-List: rudder/elev hinges
Posted: Wed Apr 14, 1999 4:39 pm
Original Posted By: Michael Cuy
I have a question about the rudder and elevator hinges. I am workingfrom the original plans which call out a fabricated hinge bent andwelded. tried a few and they are really intense. I see by the variousphotos that people are using the AN eyebolts. My AP's only concern isthat if one assy loosens and turns 90 deg , the controls will lock.Is this what they use, and has any problems come up? Whats out thereto choose from?thanks, walt evansI have a question about the rudderand elevatorhinges. I am working from the original plans which call out afabricatedhinge bent and welded. tried a few and they are really intense. Isee bythe various photos that people are using the AN eyebolts. My AP'sonlyconcern is that if one assy loosens and turns 90 deg , the controls willlock.Is this what they use, and has anyproblems comeup? Whats out there to choose from?thanks, waltevans________________________________________________________________________________
Posted: Wed Apr 14, 1999 4:52 pm
Original Posted By: Bill Talbert
>> I have a question about the rudder and elevator hinges. I am working from> the original plans which call out a fabricated hinge bent and welded. tried> a few and they are really intense. I see by the various photos that people> are using the AN eyebolts. My AP's only concern is that if one assy loosens> and turns 90 deg , the controls will lock.> Is this what they use, and has any problems come up? Whats out there to> choose from?> thanks, walt evansPasted from Grant's page below. Hope this helps Walt. I wish I hadbought these from Vi.....instead I was stubborn and spent at least a weekmaking mine from 4130. Mike C. (12/19/98) Vi Kapler makes, and offers: Corvair propeller hub . . . . $200 Corvair intake manifold . . . . $175 Air Camper tail group hinges nine pair, holes drilled, need some finishing with file . . . $35 Coming soon: Mechanical tach drive for Corvair === 1033 Forest Hills Drive SW === Rochester MN 55902 === 507-288-3322 Newcomers may not know it was Vi who kept Pietenpol Field at Cherry Grove open for its final few years and he was the one who drew the plans for the 3-piece wing -- developed during his tenure at C.G. . . . gem I have a question about therudder and elevator hinges. I am working from the original planswhich call out a fabricated hinge bent and welded. tried a few andthey are really intense. I see by the various photos that people areusing the AN eyebolts. My AP's only concern is that if one assyloosens and turns 90 deg , the controls will lock.Is this what they use, and has any problems come up? Whatsout there to choose from?thanks, walt evansPasted from Grant's page below. Hope this helps Walt. Iwish I hadbought these from Vi.....instead I was stubborn and spent at least aweekmaking mine from 4130. Mike C. (12/19/98) Vi Kapler makes, and offers:Corvair propeller hub . . . . $200Corvair intake manifold . . . . $175Air Camper tail group hingesnine pair, holes drilled, needsome finishing with file . . . $35Coming soon:Mechanical tach drive for Corvair=== 1033 Forest Hills Drive SW=== Rochester MN 55902=== 507-288-3322Newcomers may not know it was Vi who kept Pietenpol Field atCherry Grove open for its final few years and he was the onewhodrew the plans for the 3-piece wing -- developed during his tenureatC.G. . . . gem ________________________________________________________________________________
Posted: Wed Apr 14, 1999 5:32 pm
Mike, I too was stubborn and spent quite a bit of time building mine per the plans(after first building a hydraulic bending rig). I was quite proud of my set ofhinges and my interpretation of the (somewhat vague) plans until my AN hardware(clevis pins and pan head screws for hinge attachment) arrived, and I realizedthat, using the dimensions in the plans, I could not install the clevis pins with the hinges attached to the elevator and stabilizer.I've been working on other things until I'm able to muster the gumption to makea set of "taller" hinges. Did you encounter the same interference problem I did? If so, how did you solve it?My toughest challenge the first time around was making a good, but "flat" weldto join each of the hinge pieces. I ended up MIG welding the female hinges, and gas welding the male, just because this seemed to work well for me. Also,I bent each piece and welded them together before trimming to final dimensionswith a band saw. I figured this would keep my out of any trouble with miscalculating setback. All in all, it has been pretty time consuming, but (hopefully) it will be worth the effort to have an authentic Piet.-Bill> > Pasted from Grant's page below. Hope this helps Walt. I wish I had> bought these from Vi.....instead I was stubborn and spent at least a week> making mine from 4130. Mike C. ________________________________________________________________________________
Posted: Wed Apr 14, 1999 7:37 pm
Original Posted By: arkiesacres(at)juno.com
I used eyebolts for elevator and rudder hinges. I spent a lot of effort making sure that they wouldn't turn and lock up but, because they don't share the same axis, they cannot turn, and, with three on each panel, they don't lock up.Jim Malley________________________________________________________________________________
Pietenpol-List: Fw: rudder/elev hinges
Posted: Wed Apr 14, 1999 8:01 pm
Original Posted By: GMalley(at)aol.com
Jim,Thanks for your response. Nice to see that you never had a problem withthose hinges.I assume that you are the builder of the infamous Pietenpol that was on thefront of Kitplanes a few years ago. It was after reading your article thatI made the decision to build an Aircamper. ( I still have that issue).Walt Evans-----Original Message-----
Posted: Thu Apr 15, 1999 7:48 am
>Mike, >I too was stubborn .......> and I realized>that, using the dimensions in the plans, I could not install the clevis pins >with the hinges attached to the elevator and stabilizer.>a set of "taller" hinges. Did you encounter the same interference problem I >did? If so, how did you solve it?Bill- Exactly. I made ALL of my Piet fittings a little longer upon the adviceofseveral builders who were ahead of me and had encountered the same promblem(s)you mention. As drawn, the evel/rudder hinges are really, really tight if notimpossibleto install. I made the mounting 'legs' longer to spread the load over moresurfacearea and extended the clevis 'leg' somewhat because I chose to recess thesefittingsinto the edges of the wood. Mike C. Mike, I too was stubborn ....... and I realizedthat, using the dimensions in the plans, Icould not install the clevis pins with the hinges attached to the elevator and stabilizer.a set of taller hinges. Did you encounter the sameinterference problem I did? If so, how did you solve it?Bill- Exactly. I made ALL of my Piet fittings a little longerupon the advice ofseveral builders who were ahead of me and had encountered the samepromblem(s)you mention. As drawn, the evel/rudder hinges are really,really tight if not impossibleto install. I made the mounting 'legs' longer to spread the loadover more surfacearea and extended the clevis 'leg' somewhat because I chose torecess these fittingsinto the edges of the wood. Mike C. ________________________________________________________________________________
