Pietenpol-List: helmet box latch
Posted: Wed Apr 14, 1999 5:44 pm
Original Posted By: Ken Hannan
for Mike C.,I've seen and envied pictures of your cockpit for along time now. Canyou tell me where you got that brass, flush mounted ,finger pull latch?ThanksWalt Evansfor Mike C.,I've seen and envied pictures ofyour cockpitfor along time now. Can you tell me where you got that brass, flushmounted,finger pull latch? ThanksWaltEvans________________________________________________________________________________
Pietenpol-List: Re: helmet box latch
Posted: Thu Apr 15, 1999 7:34 am
Original Posted By: Michael Cuy
>> for Mike C.,> I've seen and envied pictures of your cockpit for along time now. Can you> tell me where you got that brass, flush mounted ,finger pull latch? > Thanks> Walt EvansAha ! Why certainly, Walt. The local Woodworker's Store here in Cleve. hadthose finger pull latches in both circular and square shapes. I chose the circularones.Mostly found at refinishing shops, furniture making supply stores, orwoodworkingcatalogs. The only finger that works with mine are my pinkeys, but that's okw/ me :)PS- The catch (excuse the pun) to installing those brass pulls in a flushmannerhowever can be traced to your purchasing or borrowing the proper size Forstnerbitto recess the plywood to accept those babies. for Mike C.,I've seen and envied pictures of your cockpit for along time now. Can youtell me where you got that brass, flush mounted ,finger pull latch? ThanksWalt EvansAha ! Why certainly, Walt. The local Woodworker's Storehere in Cleve. had those finger pull latches in both circular and square shapes. I chose thecircular ones.Mostly found at refinishing shops, furniture making supply stores, orwoodworkingcatalogs. The only finger that works with mine are my pinkeys, butthat's ok w/ me :)PS- The catch (excuse the pun) to installing those brass pulls in a flushmannerhowever can be traced to your purchasing or borrowing the proper sizeForstner bitto recess the plywood to accept those babies. ________________________________________________________________________________
Posted: Thu Apr 15, 1999 2:48 pm
I haven't seen the pictures, but you just described the latch I bought formy Christavia. I got it from Lee Valley, here in Calgary. They sellspecialized tools for woodworking, gardening, etc. The also have a fullline of brass hardware inclufing heavy duty brass latches, extruded brasshinges, etc. They are both in Canada and the US. Check out:
http://www.leevalley.com for more info.KenOn Wed, 14 Apr 1999, walter evans wrote:> for Mike C., I've seen and envied pictures of your cockpit for along> time now. Can you tell me where you got that brass, flush mounted> ,finger pull latch? Thanks Walt Evans> ________________________________________________________________________________
Posted: Thu Apr 15, 1999 4:51 pm
Try this one
www.rocker.comKen ----- Original Message -----
Posted: Thu Apr 15, 1999 6:02 pm
OOPS
www.rockler.com ----- Original Message -----
