Pietenpol-List: Rudder and elevator hinges
Posted: Sat Apr 17, 1999 10:24 pm
Subject: Pietenpol-List: Rudder and elevator hinges>Walt,>>Read your messages last week on the Piet net>about hinges. I've seen some before on Piets>where the builder took pieces of square or>rectangular tubing ( I assumed it was aluminum )>and made hinges from these. They used two different>sizes that would nestle inside each other.>Wish I could draw a diagram on this thing to explain>it better, but if you use your imagination I think>you can figure it out. They cut away the top part of> the tubing to make the hinges.>>I am going to try it. I ordered two pieces of>C-channel from Wicks. It should arrive tomorrow-->so I am not speaking from a successful experience,>just what I intend to try. One piece is 1.25" O.D.>with 1/8" wall and the other is 1" O.D., also with>1/8" wall. (Aluminum--6061-T6, I think)>>I'll let you know my impressions as soon as I get a>chance to play with it. (I have never made anything>out of metal before.)>>>John in Peoria>>________________________________________________________________________________
Posted: Sun Apr 18, 1999 1:26 am
Posted: Sun Apr 18, 1999 4:28 pm
Walt,Read your messages last week on the Piet netabout hinges. I've seen some before on Pietswhere the builder took pieces of square orrectangular tubing ( I assumed it was aluminum )and made hinges from these. They used two differentsizes that would nestle inside each other. Wish I could draw a diagram on this thing to explainit better, but if you use your imagination I thinkyou can figure it out. They cut away the top part of the tubing to make the hinges. I am going to try it. I ordered two pieces ofC-channel from Wicks. It should arrive tomorrow--so I am not speaking from a successful experience,just what I intend to try. One piece is 1.25" O.D.with 1/8" wall and the other is 1" O.D., also with 1/8" wall. (Aluminum--6061-T6, I think) I'll let you know my impressions as soon as I get achance to play with it. (I have never made anything out of metal before.)John in Peoria________________________________________________________________________________
Pietenpol-List: Re: Rudder and elevator hinges
Posted: Sun Apr 18, 1999 8:10 pm
Original Posted By: John Fay
John, Couldn't you do the same thing using the same size channels? One edgewould lap over inside and the other outside. By flipping one hinge theendplay would be taken care of, maintaining position of the control surface.J Mc-----Original Message-----
Posted: Mon Apr 19, 1999 9:46 am
Original Posted By:> John Fay
Exactly what I did. In addition to the advantages you mention John, youalso have twice the bearing points.SteveeSteve EldredgeIT ServicesBrigham Young University> -----Original Message-----> John McNarry> Sent: Sunday, April 18, 1999 7:10 PM> To: Pietenpol Discussion> Subject: Re: Rudder and elevator hinges>>> John,> Couldn't you do the same thing using the same size> channels? One edge> would lap over inside and the other outside. By flipping one hinge the> endplay would be taken care of, maintaining position of the> control surface.>> J Mc> -----Original Message-----
Posted: Tue Apr 20, 1999 6:54 pm
John Do you think 4130 chrome moly steel would be a better choice than6061 T6 aluminium for the hinges? Thats what i'm going to use on my Piet.-----Original Message-----
Posted: Thu Apr 22, 1999 9:33 pm
--- SAM & JAN MARINUCCI wrote:> John> Do you think 4130 chrome moly steel would be> a better choice than> 6061 T6 aluminium for the hinges? Thats what i'm> going to use on my Piet.> -----Original Message____I'm sure 4130 is great. I would assume that the alum. version couldbe lighter, but I will have to get my engineering partner to do some work on that. I think it may beeasier to do the work on the Alum. piece. I do not have a grinder yet,and was going to try to get by on the Al. with my sander.About using two pieces of the same size channel and justreversing the direction of overlap on one of the pairs:I see two disadvantages to that. First, a slight weight and costpenalty. I can use a piece of 1" inside a piece of 1 1/4". If I usedthe overlap I would have to use two pieces of the 1 1/4" material,because two pieces of 1" material overlapped would not leave sufficientroom inside for the mounting hardware.2) There are 3 hinges pairs per elevator. With one overlapped theother direction you have two flanges keeping the elevator from movingone way, but only one flange to keep it from going the other way. With the twosize system, one nestling inside the other, you havethree flanges preventing movement in each direction.You could use two of the same size and use a spacer to prevent movement, which would solve the second concern, but why addthe complexity when it may be easier to find the right size ofC-channel than to findthe right size and type of spacer.These are my initial thoughts, but as I said--I've never done it. I'vereceived the C-channel now, but probablywon't get around to trying to make the part until June.(School's coming to an end and I am going to be superbusy the next 5 weeks.)John in Peoriato find two of the ________________________________________________________________________________
Posted: Fri Apr 23, 1999 9:21 am
Original Posted By: Doug Sheets
Sam,Jan,John:I'm making aluminum hinges from 1-3/4 x 3/4 6061T6 and using the overlap method. The only difference is that I am making them and sending them to a plating shop to be HARD anodized which puts a very hard wear surface all over. My concern was with the bearing strength of the holes. My tail section is almost done, so I can check the viability of this installation soon. My shop is slow, so I'm making a whole bunch of these. The min. charge for anodizing is $125 so I need to send a lot of them. I am currently drawing all of the metal parts in AutoCad and making the attach fitting ends 1/2" per Mike Cuys video. I'll check the results with my own installation.Doug Sheets>From: John Fay >Reply-To: Pietenpol Discussion >To: Pietenpol Discussion >Subject: Re: Rudder and elevator hinges>Date: Thu, 22 Apr 1999 19:33:15 -0700 (PDT)>>>--- SAM & JAN MARINUCCI wrote:>> John>> Do you think 4130 chrome moly steel would be>> a better choice than>> 6061 T6 aluminium for the hinges? Thats what i'm>> going to use on my Piet.>> -----Original Message____>>>I'm sure 4130 is great. I would assume that the alum. version could>be lighter, but I will have to get >my engineering partner to do some work on that. I think it may be>easier to do the work on the Alum. piece. I do not have a grinder yet,>and was going to >try to get by on the Al. with my sander.>>About using two pieces of the same size channel and just>reversing the direction of overlap on one of the pairs:>I see two disadvantages to that. First, a slight weight and cost>penalty. I can use a piece of 1" inside a piece of 1 1/4". If I used>the overlap I would have to use two pieces of the 1 1/4" material,>because two pieces of 1" material overlapped would not leave sufficient>room inside for the mounting hardware.>>2) There are 3 hinges pairs per elevator. With one overlapped the>other direction you have two flanges keeping the elevator from moving>one way, but only one >flange to keep it from going the other way. With the >twosize system, one nestling inside the other, you have>three flanges preventing movement in each direction.>>You could use two of the same size and use a spacer >to prevent movement, which would solve the second concern, but why add>the complexity when it may be easier to find the right size of>C-channel than to find>the right size and type of spacer.>>These are my initial thoughts, but as I said--I've never done it. I've>received the C-channel now, but probably>won't get around to trying to make the part until June.>(School's coming to an end and I am going to be super>busy the next 5 weeks.)>>John in Peoria>>to find two of the >>________________________________________________________________________________
Original Posted By: Michael Cuy
> Subject: Rudder and elevator hinges>>> >Walt,> >> >Read your messages last week on the Piet net> >about hinges. I've seen some before on Piets> >where the builder took pieces of square or> >rectangular tubing ( I assumed it was aluminum )> >and made hinges from these. They used two different> >sizes that would nestle inside each other.> >Wish I could draw a diagram on this thing to explain> >it better, but if you use your imagination I think> >you can figure it out. They cut away the top part of> > the tubing to make the hinges.> >> >I am going to try it. I ordered two pieces of> >C-channel from Wicks. It should arrive tomorrow--> >so I am not speaking from a successful experience,> >just what I intend to try. One piece is 1.25" O.D.> >with 1/8" wall and the other is 1" O.D., also with> >1/8" wall. (Aluminum--6061-T6, I think)> >> >I'll let you know my impressions as soon as I get a> >chance to play with it. (I have never made anything> >out of metal before.)> >> >> >John in Peoria> >> >> >> >> >> >> >>>________________________________________________________________________________
