Pietenpol-List: Re: Brakes on Jenny style straight axles
Posted: Tue May 04, 1999 10:58 pm
Original Posted By: scherer2(at)airmail.net (Glenn Scherer)
To Mike Cuy, and any of the rest of you with brakes. I machined the 4130 1.5" OD straight axle today. I have cutthreads for spindle nuts and turned the bushing section to accept myconverted motorcycle wheels. I noticed that your pictures Mike, have a shaft protruding downthrough the bottom block. Is this bolt preventing axle rotation andacting as a travel limit? How is the bolt fastened to the axle and ifthis is what you are doing is it working out well? I guess what I'm asking is how do you stop the axle from rotating asthe brakes absorb the wheels torque? John Mc________________________________________________________________________________
Posted: Wed May 05, 1999 2:19 am
Original Posted By: Doug
Subject: Re: Brakes on Jenny style straight axles To Mike Cuy, and any of the rest of you with brakes. I noticed that your pictures Mike, have a shaft protruding downthrough the bottom block. Is this bolt preventing axle rotation andacting as a travel limit? John- Yes and yes. In addition to those two issues this shaftalso prevents the axle from moving left or right as you bump along the ground. Frank Pavliga had this happenearly on and every so often they would have to shove the axle back to it's proper position under thebungees. ***as a word of caution, no matter what design you end up using to get the job done, a good thing to do is loopand nicopress a length of cable around each axle/gear leg so that if your bungee lets loose the axle won'ttravel all the way up to your belly and cause extra damage. Mike; how much travel did you allow with the stop cable? you are doing is it working out well? Actually what's happening here is that bolt or shaft is welded tothe bottom of the axle. The shaft is then run thru a collar or 'tube inside of a tube' that's welded to theinside lower steel gear fitting. A little grease there helps it not to squeak. I was wondering how loose the fit would have to be, so that theaxle could tilt and allow one side to move more relative to the other? So far the setup works very well and I'd do it again. Many solutions though to this dilemma. The WWI guys were ingeniousat solving this very problem. For more clarity I can mail you (and anyone else interested) a .jpgformat picture that shows exactly how this thing works Mike C. Yes! Please and thanks
Posted: Wed May 05, 1999 4:16 am
Subject: Re: Brakes on Jenny style straight axles To Mike Cuy, and any of the rest of you with brakes. cut threads for spindle nuts and turned the bushing section to accept myconverted motorcycle wheels.down through the bottom block. Is this bolt preventing axle rotation andacting as a travel limit? John- Yes and yes. In addition to those two issues this shaft alsoprevents the axle from moving left or right as you bump along the ground. Frank Pavliga had this happen earlyon and every so often they would have to shove the axle back to it's proper position under the bungees. ***as a word of caution, no matter what design you end up using to get the job done, a good thing to do is loop andnicopress a length of cable around each axle/gear leg so that if your bungee lets loose the axle won'ttravel all the way up to your belly and cause extra damage. you are doing is it working out well? Actually what's happening here is that bolt or shaft is welded tothe bottom of the axle. The shaft is then run thru a collar or 'tube inside of a tube' that's welded to theinside lower steel gear fitting. A little grease there helps it not to squeak. So far the setupworks very well and I'd do it again. Many solutions though to this dilemma. The WWI guys were ingeniousat solving this very problem. For more clarity I can mail you (and anyone else interested) a .jpgformat picture that shows exactly how this thing works. Mike C.________________________________________________________________________________
Posted: Wed May 05, 1999 8:16 am
>> To Mike Cuy, and any of the rest of you with brakes.> >>>> I machined the 4130 1.5" OD straight axle today. I have cut threads for>> spindle nuts and turned the bushing section to accept my converted>> motorcycle wheels. >> I noticed that your pictures Mike, have a shaft protruding down through the>> bottom block. Is this bolt preventing axle rotation and acting as a travel>> limit?>John- Yes and yes. In addition to those two issues this shaft also preventsthe axle from moving left or rightas you bump along the ground. Frank Pavliga had this happen early on and everyso often they would haveto shove the axle back to it's proper position under the bungees. ***as a wordof caution, no matter what designyou end up using to get the job done, a good thing to do is loop and nicopressa length of cable around eachaxle/gear leg so that if your bungee lets loose the axle won't travel all theway up to your belly and cause extradamage.>>>>> How is the bolt fastened to the axle and if this is what you are doing is>> it working out well?>Actually what's happening here is that bolt or shaft is welded to the bottom ofthe axle. The shaft is thenrun thru a collar or 'tube inside of a tube' that's welded to the inside lowersteel gear fitting.A little grease there helps it not to squeak. So far the setup works very welland I'd do it again.Many solutions though to this dilemma. The WWI guys were ingenious at solvingthis very problem.For more clarity I can mail you (and anyone else interested) a .jpg formatpicture that showsexactly how this thing works.Mike C. To Mike Cuy, and any of the rest of you withbrakes. I machined the 41301.5 OD straight axle today. I have cut threads for spindle nuts andturned the bushing section to accept my converted motorcycle wheels.I noticed that your pictures Mike, have a shaft protruding down throughthe bottom block. Is this bolt preventing axle rotation and acting as atravel limit?John- Yes and yes. In addition to those two issues this shaftalso prevents the axle from moving left or rightas you bump along the ground. Frank Pavliga had this happen earlyon and every so often they would haveto shove the axle back to it's proper position under the bungees.***as a word of caution, no matter what designyou end up using to get the job done, a good thing to do is loop andnicopress a length of cable around eachaxle/gear leg so that if your bungee lets loose the axle won't travel allthe way up to your belly and cause extradamage.How isthe bolt fastened to the axle and if this is what you are doing is itworking out well?Actually what's happening here is that bolt or shaft is welded to thebottom of the axle. The shaft is thenrun thru a collar or 'tube inside of a tube' that's welded to the insidelower steel gear fitting.A little grease there helps it not to squeak. So far the setupworks very well and I'd do it again.Many solutions though to this dilemma. The WWI guys were ingeniousat solving this very problem.For more clarity I can mail you (and anyone else interested) a .jpgformat picture that showsexactly how this thing works.Mike C. ________________________________________________________________________________
Posted: Wed May 05, 1999 9:57 am
Original Posted By: Michael Cuy
Mike; "ole Earl down the road here would like one! -----Original Message-----
Posted: Wed May 05, 1999 6:07 pm
Mike, I don't know what a .jpg format picture is and whether you're referring to snail or E-mail but would sure like to see anything you have that shows meyours works. I have an anti-torque devise on mine that was designed by a friend but feel there might be room for improvement. Easier to make changes now, if needed, than later.!! Thanks, Don________________________________________________________________________________
Posted: Wed May 05, 1999 8:16 pm
Posted: Thu May 06, 1999 8:23 am
>>>>>>>>>>>> Mike; how much travel did you allow with the stop cable?>>>John- My guess is about 6 to 8 inches.>>>>> I was wondering how loose the fit would have to be, so that the axle>> could tilt and allow one side to move more relative to the other?>Good point. I just got two sizes of 4130 tubing that fit inside one anotherwith a little play. Can'ttell you what sizes I used at the moment, but they are fairly tight. In thereal world my axle only movesmabye 3/4" up when taxiing and maybe 1" on a really hard landing.Mike C. Mike; how much travel did you allow with thestop cable?John- My guess is about 6 to 8 inches.I was wondering how loose the fit wouldhave to be, so that the axle could tilt and allow one side to move morerelative to the other?Good point.I just got two sizes of 4130 tubing that fit inside one another with alittle play. Can'ttell you what sizes I used at the moment, but they are fairlytight. In the real world my axle only movesmabye 3/4 up when taxiing and maybe 1 on a really hardlanding.Mike C. ________________________________________________________________________________
