Pietenpol-List: GN-1/Piet
Posted: Wed May 12, 1999 9:47 am
Randy- In addition to the good points Steve E. mentioned,the GN-1 has a 'fixed' wing position relative to the fuselage.The Piet's wing can be moved fore and aft to variousdegrees to accommodate all the marvelous combinations ofyour dreams- engine type, pilot weight, fuel locations, etc.To make your center of gravity right on a GN-1 you either have to:get it right the first time......make your engine mount longer orshorter.......or add ballast. Both planes fly very similar althoughthe Piet generally has better climb and smaller engines due to it'sinherent empty wt. being lower. Then again if a Piet is overbuilt andcomes in with too heavy of an empty weight, you can kiss theadvantage goodbye. Hope this helps !Mike C. ________________________________________________________________________________
