Pietenpol-List: First wheels I've spotted
Posted: Wed May 19, 1999 3:42 am
Original Posted By: dannymac
Subject: Pietenpol-List: First wheels I've spotted>Dear Guys,>>I had time today to run by a motorcycle salvage yard today. I found two>1973 Harley rims that looked really solid and strong. There were some>cast aluminum ones but I found a couple made of steel with cast aluminum>hubs. They were 19" and a tread with of 2.5"......The inside diameter>was large enough for a bushing on a 1.5" axle but the cast hubs troubled>me. Anyone know if I should steer clear?.......The flanges (I guess>that's what you call them, the part around the hub where the spokes go>through) were .25" thick and all of the spokes were tight even though>some had begun to rust. I noticed the diam of the spokes were larger>than most on the other rims I found in the yard. Not considerably, may>just the next size thicker. Has anyone trusted cast aluminum under THEIR>private parts?> Like I said, this is the first place I've looked. Doing what I can>till plans and materials arrive.>>________________________________________________________________________________
