Pietenpol-List: Re: Mags
Posted: Wed Jun 23, 1999 11:54 pm
Original Posted By: Greg Yotz
-----Original Message-----
Pietenpol-List: Mags
Posted: Thu Jun 24, 1999 5:54 pm
Original Posted By: Randall Reihing
Hi Everyone, As soon as I told my IA about the Army Surplus (208-529-4555) mags hecalled within one minute and ordered four. He was so enthused I ordered tenmore. How can you beat the price? Even if they are not useable you coulddonate them to an A&P school and take a tax write off. Randall Reihing Randall ReihingUniversity of ToledoCollege of EngineeringMIME Department419-530-8244FAX: 419-530-8206E-Mail: rreihing(at)eng.utoledo.edu________________________________________________________________________________
Posted: Fri Jul 16, 1999 6:22 pm
Original Posted By: David Swagler
Jerry wrote:Right. An AI told me that there is over $100 worth of parts in thosemags. Further he said they will proably fit a 0-200.Mike B Piet N687MB (Mr Sam )Jerry wrote:. I think the bestuse of these magsis forspare parts for non-certified aircraft enginesusing Slickmags.Right. An AI told me that there is over $100worth ofparts in those mags. Further he said they will proably fit a0-200.Mike B Piet N687MB (Mr Sam)________________________________________________________________________________
Posted: Sat Jul 17, 1999 8:50 pm
Original Posted By: dannymac
No , they will not fit an 0-200, I have an 0-200 and they will not fitthe accessory case...Michael Brusilow wrote:> Jerry wrote: use of these mags is for spare parts for non-certified aircraft> engines> using Slick mags.> Right. An AI told me that there is over $100 worth> of parts in those mags. Further he said they will proably fit a> 0-200. Mike B Piet N687MB (Mr Sam )No , they will not fit an 0-200, I have an 0-200 and they will not fitthe accessory case...Michael Brusilow wrote:Jerry wrote:.I think the bestuse of these mags is for spare parts for non-certifiedaircraft enginesusing Slick mags.>Right.An AI told me that there is over $100 worth of parts in those mags. Furtherhe said they will proably fit a 0-200.MikeB Piet N687MB (Mr Sam )________________________________________________________________________________
Posted: Sun Aug 27, 2000 6:39 am
I thought I had posted this, but perhaps I did not. Thanks folks for yourhelp with the timing.I now know how to time the mag. I put it together and put it back in theplane but could get no spark.I am wondering if the new coil is defective. I think it is the correctcoil.(the mag # is 10-51360-26. The coil came from Aircraft Spruce and is#10-357164-1). The coil has two leads, a long one and a short one, onecoming from each side,which I think are the same wire since there is continuity (no resistance)between them. The catalog says "furnished with long and short coil topoints leads" so thismakes sense. It has a square metal bar sticking out of each end that clampsto the mag housing andit has a little brass tab in the center of the coil that the distributorcontact pushes against. My questions are, what do I put my ohmmeter leadsagainst to test the primary and secondary resistances, and what valuesshould I expect. I get 14000 ohm if I connect the meter across the brasstab (distributer lead?) and either of the point leads. I get no reading(infinite resistance) between a point lead and the metal bar (ground?). Ialso get infinite resistance between the brass tab and the metal bar. Idon't know what else to measure. Does this sound like a defective NEW coil?If the coil checks out, is it possible to "bench test" the mag? The pointsopen and close. By the way, The mag worked fine until a couple of weeksago, and the old coil definitely seemed bad (5000 ohmbetween distributer and points, zero between points lead and ground, andplus it was cracked open and oozing resin. I am sure I connected the "pointslead "correctly, ie., to the same place the capacitor connects. Could a badcapacitor cause the mag not to work at all, or does it just cause the pointsto burn. Points look good, by the way, and the old coil was definitely inbad shape, leaking resin and cracked. What else could be wrong. Thanks foryour help. Joe Kohler. Very frustrating, but what else is new. Its all aneducation, isn't it. Hey, my kid just spent about 3 hrs trying to figurewhy the new print cartridge didn't print blue, put in the old one and gotblue. Go figure.________________________________________________________________________________
Re: Pietenpol-List: Mags
Posted: Sun Aug 27, 2000 7:40 am
----- Original Message -----
Posted: Sun Aug 27, 2000 7:42 am
I taped off the extra point lead with several layers of electrical tape. Iam sure I timed it correctly, and it didn't give a spark when I turned itover by hand or in the plane. How does one test a condenser? Joe Kohler________________________________________________________________________________
Posted: Sun Aug 27, 2000 8:30 am
Original Posted By:> Joseph Kohler
I wouldn't assume the new ciol was bad, but I have never known the properresistances to check one. I looked at the AS&S catalog and I see what youmean re: two point wires. What did you do with the extra wire? could itbe touching something? Also, I do not think the mag would work with a badcondensor. Are you sure you timed it right inside? Can't you hand testthe mag before you put it on the engine?----------
Posted: Mon Aug 28, 2000 8:11 am
Joe: It sounds like you may have some other problem. Did you take thedistributor gear out to make sure the "finger" on it is not broken and thatthe contacts on the block are OK?________________________________________________________________________________Date: Mon, 28 Aug 2000 09:31:00 -0600
Pietenpol-List: Re:Mags
Posted: Mon Aug 28, 2000 11:01 am
Original Posted By: Jim Sury
Posted: Tue Aug 29, 2000 5:42 pm
Joe, I am vindicated in my original response where I said I thought it wasa ground wire. Thanks!----------
Posted: Mon Apr 23, 2001 6:06 pm
Original Posted By: "Ed Grentzer"
Help-Help-Help Just when I think I have it all figured out, something humbles me. This time it'smy magneto. Time to poll the audience.I have a Bendix (scintilla) with an impulse coupling mounted on my "A" per Mr.Pietenpol's plans. On the bench with plugs on the wires, I can turn over the magdrive and watch each plug fire, in order, with each 360 degree rotation. Theimpulse coupler clicks and the next plug fires. I'm onmy way, right? Nope!I put the same mag, wires, plugs et al on the engine and I only get #1 and #3 tofire!! In other words, it fires a plug each 720 degrees so #2 and #4 get skippedeven though the impulse coupler is still working each 360 degrees. Thereis evidence that the same thing occurs when the engine is up to speed as thereis no soot in the corresponding exhaust pipes and no evidence of carbon on theplugs. What gives??The good news is that despite my misgivings about the engine being so tight andwith only half the cylinders firing, IT DOES RUN!!! I'm sure it'sgoing to be a lot easier to start and much smoother running when I can get allfour to light off. Thanks in advance for your inputf"http://explorer.msn.com">http://explorer.msn.com________________________________________________________________________________
Posted: Mon Apr 23, 2001 7:15 pm
Original Posted By: "Bob Seibert"
Hi Larry glad to hear your engine is turning over smoothly. I know this sounds simple but if you know the mag is working but your firing on only two cylinders you might check your firing order and direction of rotation of the wires in the cap. If the wires were in the cap in the wrong sequence two of the the plugs could be firing on a non- compression stroke such as exhaust. It's worth checking if you haven't already. If the spark plugs aren't sparking then it's in the mag or the wires or plugs. Ed G.>From: "Larry Williams" >Reply-To: pietenpol-list(at)matronics.com>To: "Pietenpol-List Digest Server" >Subject: Pietenpol-List: Mags>Date: Mon, 23 Apr 2001 19:06:33 -0400>>>Help-Help-Help>>Just when I think I have it all figured out, something humbles me. This t>imeit's my magneto. Time to poll the audience.>>I have a Bendix (scintilla) with an impulse coupling mounted on my "A" pe>r Mr.Pietenpol's plans. On the bench with plugs on the wires, I can turn> over themag drive and watch each plug fire, in order, with each 360 deg>ree rotation.The impulse coupler clicks and the next plug fires. I'm on>my way, right? Nope!>>I put the same mag, wires, plugs et al on the engine and I only get #1 an>d #3to fire!! In other words, it fires a plug each 720 degrees so #2 and> #4 getskipped even though the impulse coupler is still working each >360=> up to speed as there is no soot in the corresponding exhaust pipes >degrees. There is evidence that the same thing occurs when the engine isand n>oevidence of carbon on the plugs. What gives??>>The good news is that despite my misgivings about the engine being so tig>ht andwith only half the cylinders firing, IT DOES RUN!!! I'm sure it's>going to be a lot easier to start and much smoother running when I can ge>t allfour to light off.>>Thanks in advance for your input>>f"http://explorer.msn.com">http://explorer.msn.com>>________________________________________________________________________________Date: Tue, 24 Apr 2001 08:35:52 -0500
Re: Pietenpol-List: Radial Engine Available for Piet........
Posted: Tue Apr 24, 2001 8:37 am
Original Posted By: "Joe Krzes"
Subject: Re: Pietenpol-List: Radial Engine Available for Piet........In a message dated 4/23/01 10:58:46 AM Central Daylight Time, Michael.D.Cuy(at)grc.nasa.gov writes:Hi Guys, Just got off the phone with Frank Pavliga, what a nice guy. I told him to box up that Radial Engine, I'm on my way. Just sounds perfect for me. My Piet is ready for an engine and I did not have one yet. Now, does anyone speak Russian? I need to get a prop and I think they are in Russia.Scott DufrecheDown in Texas.>________________________________________________________________________________
Re: Pietenpol-List: Parasol Flyin
Posted: Tue Apr 24, 2001 8:58 am
Original Posted By: "Michael King"
FYI, If you want to keep track of this Parasol group, they have formed a yahoo group at the following address. Not a very active list, but they are piet friendly, whether made from wood or steel, to-plans or modified. They even welcome (gasp) GN-1's. :)Joehttp://groups.yahoo.com/group/ParasolAirplanes>From: "Bob Seibert" >I just got word that there is a "Parasol Airplanes" flyin coming up on>29 June and 1 July. It is at Osage Beach, Missouri - Grand Glaize>Airport (K15).>The flyer I saw said more info was available at>http://corbenflyer.tripod.com________________________________________________________________________________
Posted: Tue Apr 24, 2001 9:02 am
Scott,Where are you located in Texas? I am in Dallasand may be able to help you if you are in thearea.Mike KingGN-177MK----- Original Message -----
Posted: Tue Apr 24, 2001 9:09 am
Subject: Re: Pietenpol-List: Radial Engine Available for Piet........Mike, And anyone else who is working on a Piet. I am in Sanger TX. Just up the road from DFW airport. About 15 minutes north of Denton. I live on the Bar VK airpark. TX32. Flyin visit are always welcome. We are doing some work on the runway with in the next couple of days. Email or call if you want to stop by. 940-458-5612Scott.________________________________________________________________________________Date: Tue, 24 Apr 2001 11:41:17 -0700 (PDT)
Re: Pietenpol-List: radial engine
Posted: Tue Apr 24, 2001 5:33 pm
Original Posted By: "javier cruz"
Me, too!CraigStill working on the Bakeng Duce tail!----- Original Message -----
Posted: Wed Apr 25, 2001 9:32 am
The way I check to make sure that I'm getting fire to a cylinder and myproblem isn't timing or plug wires crossed, is to use a timing light. Youcan connect the timing light to each plug wire and if you get a flash thenthere is fire on the plug. If not then there is either no fire to the plugor the plug is fouled. This helped me a bunch. On none electric startengines, I use a lawn mower 12v battery and hook the timing light up to itnormally. I then tie the ground of the battery to the engine and this makesthe circuit more stable to detect the high voltage field that is in thespark plug wires.Greg________________________________________________________________________________
Original Posted By: "Joseph Kohler"
> > > I thought I had posted this, but perhaps I did not. Thanks folks foryour> help with the timing.> I now know how to time the mag. I put it together and put it back in the> plane but could get no spark.> I am wondering if the new coil is defective. I think it is the correct> coil.> (the mag # is 10-51360-26. The coil came from Aircraft Spruce and is> #10-357164-1). The coil has two leads, a long one and a short one, one> coming from each side,> which I think are the same wire since there is continuity (no resistance)> between them. The catalog says "furnished with long and short coil to> points leads" so this> makes sense. It has a square metal bar sticking out of each end thatclamps> to the mag housing and> it has a little brass tab in the center of the coil that the distributor> contact pushes against. My questions are, what do I put my ohmmeterleads> against to test the primary and secondary resistances, and what values> should I expect. I get 14000 ohm if I connect the meter across the brass> tab (distributer lead?) and either of the point leads. I get no reading> (infinite resistance) between a point lead and the metal bar (ground?). I> also get infinite resistance between the brass tab and the metal bar. I> don't know what else to measure. Does this sound like a defective NEWcoil?> If the coil checks out, is it possible to "bench test" the mag? Thepoints> open and close. By the way, The mag worked fine until a couple of weeks> ago, and the old coil definitely seemed bad (5000 ohm> between distributer and points, zero between points lead and ground, and> plus it was cracked open and oozing resin. I am sure I connected the"points> lead "correctly, ie., to the same place the capacitor connects. Could abad> capacitor cause the mag not to work at all, or does it just cause thepoints> to burn. Points look good, by the way, and the old coil was definitelyin> bad shape, leaking resin and cracked. What else could be wrong. Thanksfor> your help. Joe Kohler. Very frustrating, but what else is new. Its allan> education, isn't it. Hey, my kid just spent about 3 hrs trying to figure> why the new print cartridge didn't print blue, put in the old one and got> blue. Go figure.> > > > ________________________________________________________________________________
> >> > >> > I thought I had posted this, but perhaps I did not. Thanks folks for> your> > help with the timing.> > I now know how to time the mag. I put it together and put it back inthe> > plane but could get no spark.> > I am wondering if the new coil is defective. I think it is the correct> > coil.> > (the mag # is 10-51360-26. The coil came from Aircraft Spruce and is> > #10-357164-1). The coil has two leads, a long one and a short one, one> > coming from each side,> > which I think are the same wire since there is continuity (noresistance)> > between them. The catalog says "furnished with long and short coil to> > points leads" so this> > makes sense. It has a square metal bar sticking out of each end that> clamps> > to the mag housing and> > it has a little brass tab in the center of the coil that the distributor> > contact pushes against. My questions are, what do I put my ohmmeter> leads> > against to test the primary and secondary resistances, and what values> > should I expect. I get 14000 ohm if I connect the meter across thebrass> > tab (distributer lead?) and either of the point leads. I get no reading> > (infinite resistance) between a point lead and the metal bar (ground?).> I> > also get infinite resistance between the brass tab and the metal bar.I> > don't know what else to measure. Does this sound like a defective NEW> coil?> > If the coil checks out, is it possible to "bench test" the mag? The> points> > open and close. By the way, The mag worked fine until a couple of weeks> > ago, and the old coil definitely seemed bad (5000 ohm> > between distributer and points, zero between points lead and ground, and> > plus it was cracked open and oozing resin. I am sure I connected the> "points> > lead "correctly, ie., to the same place the capacitor connects. Could a> bad> > capacitor cause the mag not to work at all, or does it just cause the> points> > to burn. Points look good, by the way, and the old coil was definitely> in> > bad shape, leaking resin and cracked. What else could be wrong. Thanks> for> > your help. Joe Kohler. Very frustrating, but what else is new. Itsall> an> > education, isn't it. Hey, my kid just spent about 3 hrs trying tofigure> > why the new print cartridge didn't print blue, put in the old one andgot> > blue. Go figure.> >> >> >> >>>________________________________________________________________________________
Original Posted By: "mboynton(at)excite.com
> > > John and Bob, thank you. The second lead does indeed need to beconnected> to ground. (The Aircraft Spruce Catalog said it had two points leads so> because my old coil had only one lead, I thought the short one was aspare> for a different application and taped it off . I just finishedconnecting> it to ground, timed it the way Gene said, popped it in the Piet, timed itto> match the other mag a 28 BTDC and Bingo, Problem Solved. Good education.> Thanks, all.> > By the way, I also have a C-85, which is a nice engine for the Piet for> those that don't go with the Ford A. It is not certified (I had amechanic> sell it to me piece by piece and help me put it together which was a good> experience) and doesn't have to be in the US anyway. I used a blueprintfor> a Piet engine mount for the small Continentals that I believe Bernie orone> of his buddies drew up, so I guess he must have approved of thechoice!!!!> I'm not sure where it is since its been 14 years or so since I built it,but> I might be able to find it if someone needed a copy.> > > > ________________________________________________________________________________
