> > > $15.00 Magnetos
Posted: Thu Jun 24, 1999 11:38 am
Original Posted By:> > > Michael D Cuy [SMTP:Michael.D.Cuy(at)lerc.nasa.gov]
Opps, before any one flames me, that should read "cables and plugs" ;-)KenOn Thu, 24 Jun 1999, Ken Beanlands wrote:> My understanding is that only the cables are shielded.> > Ken> > On Thu, 24 Jun 1999 steve(at)byu.edu wrote:> > > Just called and ordered 2 mags They have over 100 left. Even if you never> > use them they are a great deal! BTW does anyone know if they are shielded> > or non shielded? Or is the difference only in the wiring harness to the> > plugs?> > > > Steve Eldredge> > IT Services> > Brigham Young University> > > > > -----Original Message-----> > > Behalf Of Chad Johnson> > > Sent: Monday, June 21, 1999 11:25 AM> > > To: Pietenpol Discussion> > > Subject: $15.00 Magnetos> > >> > > Hello again group.> > >> > > I have had a large response to the magnetos I mentioned> > > earlier so I will post the source here. Yes they really are> > > $14.95 US. I sent a personal check to : Army Surplus> > > Warehouse, 635 w. Broadway, P.O. Box 1523, Idaho Falls, ID.> > > 83403, 208-529-4753. I opened one of mine and compared it> > > side by side with a Slick taken from a Cont. O-200. Most> > > part numbers are the same. Only slight differences in the> > > case. I talked directly with Slick and they confirmed the> > > quality. Niether they nor the supplier knows what type of> > > engine these mags fit but that it was most likely a GPU> > > (Ground Power Unit). They come brand new, sealed in the box.> > > For 15.00 bucks it might be worth your money to find out if> > > they would work for you. To be clear, I am not the supplier,> > > I just wanted to pass along a possible bargin. Let me know> > > what you think. Chad> > >> > > -----Original Message-----
