engine mount question
Posted: Sun Jul 04, 1999 10:09 pm
Original Posted By: Ken Hannan
Subject: engine mount question This is to all of you experienced guys who have fought through theW/B for a 65 Cont. I have started to make some brackets, and thinking about the mount. Everyone talks of the Aircamper being tail heavy as a rule. I'm 220#, and planned on adding 1" to the mount. Does this soundright to you guys? The rest of the plane will be made per prints. thanks, walt evans________________________________________________________________________________
Original Posted By: pschultz(at)uplogon.com (Paul Schultz)
Subject: engine mount question This is to all of you experienced guys who have fought throughthe W/B for a 65 Cont. I have started to make some brackets, and thinking about themount. Everyone talks of the Aircamper being tail heavy as a rule. I'm 220#, and planned on adding 1" to the mount. Does thissound right to you guys? The rest of the plane will be made perprints. thanks, walt evans________________________________________________________________________________
Pietenpol-List: Re: engine mount question
Posted: Mon Jul 05, 1999 1:40 am
Subject: Pietenpol-List: Re: engine mount question This is to all of you experienced guys who have fought through theW/B for a 65 Cont. I have started to make some brackets, and thinking about the mount. Everyone talks of the Aircamper being tail heavy as a rule. I'm 220#, and planned on adding 1" to the mount. Does this soundright to you guys? The rest of the plane will be made per prints. thanks, walt evans>>> Walt, are you building the long or short fuselage? If it's thelong, I think you are going to have a problem. Mike B -Piet N6876MB ( Mr Sam ) ________________________________________________________________________________
Pietenpol-List: engine mount question
Posted: Mon Jul 05, 1999 3:05 pm
This is to all of you experienced guys who have fought through the W/Bfor a 65 Cont.I have started to make some brackets, and thinking about the mount.Everyone talks of the Aircamper being tail heavy as a rule.I'm 220#, and planned on adding 1" to the mount. Does this sound rightto you guys? The rest of the plane will be made per prints.thanks,walt evansThis is to all of you experiencedguys who havefought through the W/B for a 65 Cont.I have started to make somebrackets, andthinking about the mount.Everyone talks of the Aircamperbeing tail heavyas a rule.I'm 220#, and planned on adding1 to themount. Does this sound right to you guys? The rest oftheplane will be made per prints.thanks,waltevans________________________________________________________________________________
Posted: Mon Jul 05, 1999 5:36 pm
Posted: Mon Jul 05, 1999 10:13 pm
x-mac-creator="4D4F5353"Walt,I weigh about 160 and rocked my wings back 3 1/2 inches and added 1 inchto the engine mount for the C-65. Trims out just right.Craig________________________________________________________________________________
Fw: engine mount question
Posted: Mon Jul 05, 1999 10:29 pm
Original Posted By: Copinfo
Subject: Fw: engine mount question Copinfo, Did you make the long fuselage? walt -----Original Message-----
Posted: Tue Jul 06, 1999 5:40 am
Subject: Pietenpol-List: Re: engine mount question This is to all of you experienced guys who have fought through theW/B for a 65 Cont. I have started to make some brackets, and thinking about the mount. Everyone talks of the Aircamper being tail heavy as a rule. I'm 220#, and planned on adding 1" to the mount. Does this soundright to you guys? The rest of the plane will be made per prints. thanks, walt evansWalt- I'm 205 w/ a short fuse Piet. I added one inch also but to do itover wouldgo 2". My wings are aft 4" of upright. Nose fuel, 17 gals. Flieswonderful untilyou get down to about 7 gals, then a little tail heavy.Mike C.________________________________________________________________________________
Posted: Tue Jul 06, 1999 6:53 am
Subject: Pietenpol-List: Re: engine mount questionI just finsihed putting an A-65 on my Piet. I made the mount 4 incheslonger than the plans. It flys well but still needs forward trim. -----Original Message-----
Subject: Re: engine mount question I just finsihed putting an A-65 on my Piet. I made the mount 4inches longer than the plans. It flys well but still needs forwardtrim. -----Original Message-----
Posted: Tue Jul 06, 1999 9:38 am
>> This is to all of you experienced guys who have fought through the W/B for a> 65 Cont.> I have started to make some brackets, and thinking about the mount.> Everyone talks of the Aircamper being tail heavy as a rule.> I'm 220#, and planned on adding 1" to the mount. Does this sound right to> you guys? The rest of the plane will be made per prints.> thanks,> walt evansWalt- I'm 205 w/ a short fuse Piet. I added one inch also but to do it overwouldgo 2". My wings are aft 4" of upright. Nose fuel, 17 gals. Flies wonderfuluntilyou get down to about 7 gals, then a little tail heavy.Mike C. ________________________________________________________________________________
Posted: Tue Jul 06, 1999 10:40 am
I just finsihed putting an A-65 on my Piet. I made the mount 4 incheslonger than the plans. It flys well but still needs forward trim.-----Original Message----- Date: Monday, July 05, 1999 3:09 PM Subject: engine mount question This is to all of you experienced guys who have fought through theW/B for a 65 Cont. I have started to make some brackets, and thinking about the mount. Everyone talks of the Aircamper being tail heavy as a rule. I'm 220#, and planned on adding 1" to the mount. Does this soundright to you guys? The rest of the plane will be made per prints. thanks, walt evans________________________________________________________________________________
Pietenpol-List: Fw: engine mount question
Posted: Tue Jul 06, 1999 3:12 pm
Mike, I'm building the long fuse. What's the problem? Will I need more?walt-----Original Message-----
Posted: Tue Jul 06, 1999 3:22 pm
understanding was that, if you use a Continental, make the longfuselage and the mount per his plans, ( all plans gotten from Pietenpolfamily) , you were pretty much in the ballpark. Just figured I'd justhave to fudge for my weight.walt-----Original Message-----
Posted: Tue Jul 06, 1999 3:24 pm
Copinfo,Did you make the long fuselage?walt-----Original Message-----
Posted: Wed Jul 07, 1999 5:02 pm
Yes I have the longer fuselage. The Improved 1932 version. The A-65only weighs 170 pounds, so, it has to go out further or your wing willhave to move back to accomplish the balance you need.-----Original Message-----
