Pietenpol-List: cabane details
Posted: Sun Aug 01, 1999 4:39 am
Original Posted By: Keith Hodge
Subject: Pietenpol-List: cabane details>Hi group:>Are the bracing tubes that angle down and forward from the front cabanes>required? Doug Bryant, our local Piet guru, says no. Fact or heresy?>>Thanks.>CJ Beck>________________________________________________________________________________
Posted: Sun Aug 01, 1999 9:37 am
Original Posted By: Copinfo
Hi group:Are the bracing tubes that angle down and forward from the front cabanes required? Doug Bryant, our local Piet guru, says no. Fact or heresy?Thanks.CJ Beck________________________________________________________________________________
Pietenpol-List: Re: cabane details
Posted: Sun Aug 01, 1999 10:28 am
Original Posted By: Joe & Marian Beck
How would you keep the wing from moving forward or back without them? Mineare adjustable and I put the wing back a could of inches by adjusting them.Copinfo(at)ix.Netcom.ComTim CunninghamDes Moines, Iowa (515) 237-1510-----Original Message-----
Posted: Sun Aug 01, 1999 11:27 am
Original Posted By: Bill Talbert
plans show crossed cables between front and rear cabanes on one side only asfore aft wing supports but most builders elect to use tubing supports fromfront top motor mount to front cabaneJoeCJoe & Marian Beck wrote:> Hi group:> Are the bracing tubes that angle down and forward from the front cabanes> required? Doug Bryant, our local Piet guru, says no. Fact or heresy?>> Thanks.> CJ Beck> ________________________________________________________________________________
Posted: Mon Aug 02, 1999 1:22 pm
Original Posted By:> Joe & Marian Beck
The originals did not use the tube braces,but relied on an "X" cablebracing on one side between the cabane uprights.
Posted: Mon Aug 02, 1999 2:53 pm
Original Posted By: fishin
If you have ever flown in the front seat of a Piet with crossed cablebraces . you will use strut braces instead. The cables make entry andexittough on small people, impossible for large or older less agile folk.besides Bernie used them. If you want to stay fathfull to the original plan like Howard Hendersondid. Then go with the cables. But If you want your wife and friends toenjoy the experence, use the braces. Also in the unlikly event of anaccident. The cables restrict the passengers exit options to the leftside of the aircraft. I guess thats about two cents worth.________________________________________________________________________________
> cabane details
Original Posted By: Doug
> > Hi group:> Are the bracing tubes that angle down and forward from the front cabanes > required? Doug Bryant, our local Piet guru, says no. Fact or heresy?> > Thanks.> CJ Beck> ________________________________________________________________________________
