Pietenpol-List: if it ain't broke, don't fix it
Posted: Sat Aug 14, 1999 2:30 pm
Original Posted By: Doug Page
With all of the discussion about the wall thickness on the landing gearhinge points, I went down and measured . Mine are made to thePietenpol prints.The remaining wall thickness on my fittings andmatching gear is .090" , final drilled for 5/16" bolts. That seems likeits plenty of meat to me. Just remember, that narrowest wall is never being pulled on,( intension) , when on the ground ,or for normal landings. Both thick sidesare in compression. There won't be very many times that piece will bepulled on. If it's true that a Piet has never had an accident , in 70 years, dueto a problem with design, then that means that one of these has neverbroken.Walt EvansWith all of the discussion about thewallthickness on the landing gear hinge points, I went down andmeasured. Mine are made to the Pietenpol prints.The remaining wallthickness on myfittings and matching gear is .090 , final drilled for 5/16bolts. That seems like its plenty of meat to me. Just remember,that narrowestwall is never being pulled on,( in tension) , when on the ground ,or fornormallandings. Both thick sides are in compression. There won'tbe verymany times that piece will be pulled on. If it's true that a Piet hasnever had anaccident , in 70 years, due to a problem with design, then that meansthat oneof these has never broken.WaltEvans________________________________________________________________________________
