Pietenpol-List: to clarify bending of cap strips
Posted: Sun Aug 15, 1999 6:22 pm
Original Posted By: robert hensarling
Some RE's came back that seemed pretty complicated. Like I'd written,that from start to finish( not counting boiling the water) takes tenminutes. maybe the other methods are needed for different glues, butI'm using T-88. If you read the specs. T-88 works just as good on wetwood as dry.waltSome RE's came back that seemedprettycomplicated. Like I'd written, that from start to finish( notcountingboiling the water) takes ten minutes. maybe the other methods areneededfor different glues, but I'm using T-88. If you read the specs.T-88 worksjust as good on wet wood as dry.walt________________________________________________________________________________
