Pietenpol-List: Re: PLAN ERRORS/CLARIFICATIONS
Posted: Sun Aug 15, 1999 10:13 pm
Original Posted By: "Conrad, Bart D"
Whats the Supplementary Plans? and how many sets of plans do you need to buy tobuild this airplane?Gordon"Conrad, Bart D" wrote:> Before I add this to the KNOWN PLAN ERRORS section of aircamper.org, does everyoneagree with the following?>> 1. The "Supplementary Plans, Air-Camper" page lists the length of the fuselagefor the horizontal stabilizer to attach to, to be 18 7/8 inch. Believe thisshould maybe be 18 1/8 inch as the horizontal stabilizer is 18 inches wide. This matches the rudder length also.>> 2. Drawing number 1 of the 1933 plans does not show the width dimension of thefueslage aft most point. After reading the Flying Manual, it should be 1 1/8inch wide (without gussets).>> 3. Engine mount fittings do not show a radius in the corners. It would be goodpractice to put in a radius to avoid cracking.>> Bart D Conrad> Boeing Field Service> DC-9/MD-80/DC-10 & 737 Heavy Mtc> Phone: 713-640-5882/713-324-4192> Fax: 713-640-5891> Pager: 713-318-1625________________________________________________________________________________
