RIB TESTING RESULTS
Posted: Fri Aug 20, 1999 9:16 pm
Subject: RIB TESTING RESULTS Group, I , like many of you, have been searching for an alternative toSitka for use on the Pietenpol. I have been intrigued by Western Red Cedar ever since seeing some exceptional 4x4's at alocal lumber co. The grade was called "ornamental/ deck" and the grading gave me goose bumps. One of the 8 footers hadperfectly vertical grain the full 8ft. When I ripped it the kerf followed the same growth ring nearly full length. I havetried with no success to get more detailed comparative info. from ForestProducts Laboratory in Madison, WI. Not to be discouraged, I built a ribusing the WRC, 1/16GL-2 3ply and T88. Using the guidelines suggested in AirCamper.org/info/tips andtricks/testing rib strength, I built a test jig that uses controlled spring force vs. bulk weight. I applied the force at theincremental spacing listed. I was very pleased to see the 204# load with no ill effects. I continued to load in 1.4#increments until I ran out of spring travel, at which point the rib sustained a 358# load! I would be interested in hearing fromthose of you have have tested ANY ribs and what pitfalls I might face with using the WRC for ribs. By the way a4x4x8ft. "post" was $20. Two of them will make 90 cap strips.________________________________________________________________________________
Pietenpol-List: RIB TESTING RESULTS
Posted: Sat Aug 21, 1999 2:08 pm
Group, I , like many of you, have been searching for an alternative toSitka for use on the Pietenpol. I have been intriguedby Western Red Cedar ever since seeing some exceptional 4x4's at a locallumber co. The grade was called "ornamental/deck" and the grading gave me goose bumps. One of the 8 footers hadperfectly vertical grain the full 8ft. When I rippedit the kerf followed the same growth ring nearly full length. I havetried with no success to get more detailed comparative info. from ForestProducts Laboratory in Madison, WI. Not to be discouraged, I built a ribusing the WRC, 1/16GL-2 3ply andT88. Using the guidelines suggested in AirCamper.org/info/tips andtricks/testing rib strength, I built a test jig that usescontrolled spring force vs. bulk weight. I applied the force at theincremental spacing listed. I was very pleased to seethe 204# load with no ill effects. I continued to load in 1.4#increments until I ran out of spring travel, at which pointthe rib sustained a 358# load! I would be interested in hearing fromthose of you have have tested ANY ribs and whatpitfalls I might face with using the WRC for ribs. By the way a 4x4x8ft."post" was $20. Two of them will make 90 capstrips.Group, I , like many of you, have been searching for analternative to Sitka for use on the Pietenpol. I have been intriguedby Western Red Cedar ever since seeing some exceptional 4x4's at alocal lumber co. The grade was called "ornamental/deck" and the grading gave me goose bumps. One of the 8 footers hadperfectly vertical grain the full 8ft. When I rippedit the kerf followed the same growth ring nearly full length. I havetried with no success to get more detailed comparative info. from ForestProducts Laboratory in Madison, WI. Not to be discouraged, I built a ribusing the WRC, 1/16GL-2 3ply andT88. Using the guidelines suggested in AirCamper.org/info/tips andtricks/testing rib strength, I built a test jig that usescontrolled spring force vs. bulk weight. I applied the force at theincremental spacing listed. I was very pleased to seethe 204# load with no ill effects. I continued to load in 1.4# incrementsuntil I ran out of spring travel, at which pointthe rib sustained a 358# load! I would be interested in hearing fromthose of you have have tested ANY ribs and whatpitfalls I might face with using the WRC for ribs. By the way a 4x4x8ft."post" was $20. Two of them will make 90 capstrips.________________________________________________________________________________
Pietenpol-List: Re: RIB TESTING RESULTS
Posted: Sat Aug 21, 1999 3:30 pm
Original Posted By: mike cushway
There was an article in KitPlanes about a plane built completely withWestern Red Cedar a couple of years ago. Nice looking plane.John W -----Original Message-----
Posted: Sat Aug 21, 1999 4:57 pm
Steve wrote:Is there anyone here that can tell me where I can buy some of thiswestern red cedar?? I live in Mississippi so I am looking near here orhow can I order some and NOT break the home bank.Stevewrites:> Group,> I , like many of you, have been searching for an alternative to> Sitka for use on the Pietenpol. I have been intrigued> by Western Red Cedar ever since seeing some exceptional 4x4's at a > local> lumber co. The grade was called "ornamental/> deck" and the grading gave me goose bumps. One of the 8 footers had> perfectly vertical grain the full 8ft. When I ripped> it the kerf followed the same growth ring nearly full length. I have> tried with no success to get more detailed comparative info. from > Forest> Products Laboratory in Madison, WI. Not to be discouraged, I built a > rib> using the WRC, 1/16GL-2 3ply and> T88. Using the guidelines suggested in AirCamper.org/info/tips and> tricks/testing rib strength, I built a test jig that uses> controlled spring force vs. bulk weight. I applied the force at the> incremental spacing listed. I was very pleased to see> the 204# load with no ill effects. I continued to load in 1.4#> increments until I ran out of spring travel, at which point> the rib sustained a 358# load! I would be interested in hearing from> those of you have have tested ANY ribs and what> pitfalls I might face with using the WRC for ribs. By the way a > 4x4x8ft.> "post" was $20. Two of them will make 90 cap> strips.________________________________________________________________________________
