tailwheel cable attach points?
Posted: Sat Aug 21, 1999 12:04 am
Subject: tailwheel cable attach points? I guess this has been done many different ways but, I have the tailassy per the print with the coil spring and swing arms. Instead of theskid/blade, added on a swiveling steerable tailwheel. Should the wheel be steered by cables attached to rudder cablesinside the fuse ( more cables to pierce the skin) , or are they hookedto a horn on the rudder itself? If so, wouldn't this put too muchtwisting force on the rudder wood structure? If from the fuse rudder cables, at what distance forward in thetail? need all your input. thanks, Walt________________________________________________________________________________
Pietenpol-List: tailwheel cable attach points?
Posted: Sat Aug 21, 1999 5:03 pm
Original Posted By: GREA738(at)aol.com
I guess this has been done many different ways but, I have the tail assyper the print with the coil spring and swing arms. Instead of theskid/blade, added on a swiveling steerable tailwheel.Should the wheel be steered by cables attached to rudder cables insidethe fuse ( more cables to pierce the skin) , or are they hooked to ahorn on the rudder itself? If so, wouldn't this put too much twistingforce on the rudder wood structure? If from the fuse rudder cables, at what distance forward in the tail?need all your input.thanks,WaltI guess this has been done manydifferent waysbut, I have the tail assy per the print with the coil spring and swingarms. Instead of the skid/blade, added on a swivelingsteerabletailwheel.Should the wheel be steered bycables attachedto rudder cables inside the fuse ( more cables to pierce the skin) , orare theyhooked to a horn on the rudder itself? If so, wouldn't this puttoo muchtwisting force on the rudder wood structure?If from the fuse ruddercables, at whatdistance forward in the tail?need all your input.thanks,Walt________________________________________________________________________________
Pietenpol-List: Re: tailwheel cable attach points?
Posted: Sat Aug 21, 1999 6:08 pm
Original Posted By: Copinfo
DO NOT connect the tail wheel steering to the rudder post. It was NOT designed to take the torsional stress.There are other ways, full swivel or swivel & lock for take off is good.Other ideas ???DG________________________________________________________________________________
Posted: Sat Aug 21, 1999 6:25 pm
Walt, I'm no expert, but I have a second set of cables going to the tailwheel. J-3 Cubs and others are attached to the rudder. I don't knowwhy ours aren't. I tseemed odd to me to have extra holes in the fabric. I did it according to plans and have the extra holes. I'd do itdifferent next time.Copinfo(at)ix.Netcom.ComTim CunninghamDes Moines, Iowa (515) 237-1510-----Original Message-----
Posted: Sat Aug 21, 1999 8:36 pm
Walt, I attached to the rudder cables as they came back just behind the pilot's seat, with just enough movement allowed to avoid interference. I also made my rudder stops using swaged sleeves on the rudder cable. They hit against the seat structure which may not be the best solution and may have to be modified after I see how they work in the real world. Don Hicks ________________________________________________________________________________
Posted: Sat Aug 21, 1999 8:51 pm
Walt Evans....Walt, I neglected to say that the attach at the tailwheel is on horns that are a part of the full swivel tailwheel assbly. This is a small lightweight unit that I bought from a source in Calif. I used it before on another plane with no problems.Don Hicks ________________________________________________________________________________
Posted: Sun Aug 22, 1999 3:17 am
Original Posted By: TXTdragger(at)aol.com
Subject: Pietenpol-List: Re: tailwheel cable attach points?>Saw Piet with tail wheel horn cable, attached to rudder horn cable, priorto>rudder cable entry into fuse. Didn't pay that much attention to clamping>device but was a clean connection. This was on an old Piet (at SportFlyers>airport northwest of Houston) so it must have worked. This Piet didn'thave>cutout in wing above pilot area. I would not like that at all, too old to>fight entry hassle, not to mention lack of visibility forward & up.>>John D________________________________________________________________________________
Posted: Sun Aug 22, 1999 8:15 am
Saw Piet with tail wheel horn cable, attached to rudder horn cable, prior to rudder cable entry into fuse. Didn't pay that much attention to clamping device but was a clean connection. This was on an old Piet (at Sport Flyers airport northwest of Houston) so it must have worked. This Piet didn't have cutout in wing above pilot area. I would not like that at all, too old to fight entry hassle, not to mention lack of visibility forward & up.John D________________________________________________________________________________
Posted: Sun Aug 22, 1999 9:26 am
This conversation begs for the introduction of the idea that a direct cablelinkage to the tail wheel horn leaves one open to loss of rudder control ifthe tail wheel should be damaged or jammed in some way. Including a springin the tail wheel link allows forcefully over-riding the spring to get atleast some rudder control. Having suffered a damaged tail wheel, I canassure you that rudder control takes on new meaning. Of course, it becomesanother one of those compromise things where you have to decide how strongthe springs should be to allow tail wheel authority and still be able toover-ride it.John WKerrville, Txjandd(at)maverickbbs.com -----Original Message-----________________________________________________________________________________
Posted: Sun Aug 22, 1999 3:52 pm
Most people connect the tailwheel steering cables to the rudder cables,swedging outside the plane after the rudder cables exit the fuselage.These cannot be connected direct, but must have a spring at the tailwheelsteering arm so the rudder and tailwheel can have some independentmovement.John Langston>DO NOT connect the tail wheel steering to the rudder post. It was NOT >>designed to take the torsional stress.>There are other ways, full swivel or swivel & lock for take off is >good.>Other ideas ???>DG__________________________________________________________________________________________
Posted: Mon Aug 23, 1999 9:18 am
Original Posted By: Joe Santana
BHP recommended attaching the tailwheel steering cables to the rudder bar4 inches out from the pivot point.This info is on the supplemental plans sold by Orrin Hoopman.Greg Cardinal>>> walter evans 08/21 4:03 PM >>>I guess this has been done many different ways but, I have the tail assyper the print with the coil spring and swing arms. Instead of theskid/blade, added on a swiveling steerable tailwheel.Should the wheel be steered by cables attached to rudder cables inside thefuse ( more cables to pierce the skin) , or are they hooked to a horn onthe rudder itself? If so, wouldn't this put too much twisting force onthe rudder wood structure? If from the fuse rudder cables, at what distance forward in the tail?need all your input.thanks,Walt________________________________________________________________________________
