Pietenpol-List: Re: Titebond II
Posted: Mon Jul 26, 1999 3:08 pm
Original Posted By: Lauren Williams
Yes but since I don't plan on boiling my airplane why should I worryabout a boil test, I doubt if any epoxy glues will pass a boil test howeverthey are the first choice of many of the old school boat builders,sail boatspowered run about etc. The point is no one glue is perfect, each has it'sstrengths and weakness'. The marine epoxy I use is Raka Epoxy you canfind it one the net, one of the advantages is it'll gap fill like crazy andtheglue in the joint is stronger than the wood itself, The advantage with theTiteBond is that ventilation and rubber gloves is not needed but neitherof these glues will pass a boil test. The birch ply soaks the epoxy up andsometimes traces are seen coming through the other side of the 1/16ply. Also epoxy doesn't need the clamping pressures other glues need!I do however plan on painting my wings white as with any epoxy planeto keep temperatures down as much as possible.----- Original Message -----________________________________________________________________________________
Posted: Tue Jul 27, 1999 11:07 am
Yes there are four different polyurethane glues tested in one of the experimenters, there doesn't seem to be any thing wrongwith the glue, however it doesn't quite stand up to resorcinol in thesetest, just call the EAA and order the issue with the test comparison.Also don't repeat me on this but I think Roger Mann is usingthis type glue in his ultra light (polyurethane no brand name) designs suchas the ultra Piet.I choose epoxy because a fellow EAA member uses it andI'm impressed with his own mixed breed design. Russell----- Original Message -----________________________________________________________________________________
Pietenpol-List: Titebond II
Posted: Fri Aug 27, 1999 9:12 am
Steve wrote:I am interested in using this glue on my project. How bout more feedbackon it! Steve________________________________________________________________________________
Posted: Fri Aug 27, 1999 9:25 am
Original Posted By: Joe Krzes
>Steve wrote:>I am interested in using this glue on my project. How bout more feedback>on it! >SteveA local guy just built a set of laminated spruce landinggear legs for his Fly Baby and he used Titebond II, testing samples in the vise, soaked in water for two weeks, withPERFECT results. I would not hesitate to use this.Mike C. ________________________________________________________________________________
Posted: Fri Aug 27, 1999 10:46 am
Original Posted By: Mike Cunningham
The test for waterproofness in glue is to BOIL it water.________________________________________________________________________________
Posted: Fri Aug 27, 1999 2:13 pm
>The test for waterproofness in glue is to BOIL it water.>>How about making a plywood floats with TB II and landing in "sleep" volcanolake?That will be a real boiling test
(Couldnt stop this one)I did boil (for 5 minutes) a piece 2 years ago let it cool, it was stillbonded, but pulling hard it did unglue, but I will never boil my plane,would'nt even dare to live it outside in a rainy day.... We love them somuch to be that cruel...SaludosGary Gower________________________________________________________________________________
Posted: Fri Aug 27, 1999 5:39 pm
>>The test for waterproofness in glue is to BOIL it water.>>>>>>Another point to consider, if the wood "breaks" instead of the wood whenpulling apart, and is waterprof enough almost to boiling point... the testpieces resist sun, rain and time for several years unprotected we will...Remember that the wood on the plane is going to be protected (includingglue) with poliurethane (sp?) barnish, that is really resistant to water,the plane will be hangared when not flying, the pilot will have enough careto not get into rain when flying, if it gets a little wet he will dry itfast with a cloth. Then we would ask: When is the glue going to get enough water to melt? Remember when planeswere made with Casein glue (we are maybe to young, so read some aviationhistory
that was a glue that melted with water, they only resist becausewhere covered with some sort of "marine barnish", (Remember no certifiedaircraft parts available) these planes (or parts of them) are still in onepiece in museums.Do your testing and get confidence yourself, I got enough confidence forusing this glue nothing has unglued in several years. I am curious to knowwhen Franklin Co. begin manufacturing the TB II, just for lerning...Buy the way, working with Resorcinol did not make me happy, to complicatedto get a perfect bond, and the risk of not being well done is still there...certified or not.SaludosGary Gower________________________________________________________________________________
Posted: Fri Aug 27, 1999 5:46 pm
>>>The test for waterproofness in glue is to BOIL it water.>>>>Another point to consider, if the wood "breaks" instead of the wood when>pulling apart, and is waterprof enough almost to boiling point... the test>pieces resist sun, rain and time for several years unprotected we will...>>Remember that the wood on the plane is going to be protected (including>glue) with poliurethane (sp?) barnish, that is really resistant to water,>the plane will be hangared when not flying, the pilot will have enough care>to not get into rain when flying, if it gets a little wet he will dry it>fast with a cloth. >>Then we would ask: >>When is the glue going to get enough water to melt? Remember when planes>were made with Casein glue (we are maybe to young, so read some aviation>history
that was a glue that melted with water, they only resist because>where covered with some sort of "marine barnish", (Remember no certified>aircraft parts available) these planes (or parts of them) are still in one>piece in museums.>>Do your testing and get confidence yourself, I got enough confidence for>using this glue nothing has unglued in several years. I am curious to know>when Franklin Co. begin manufacturing the TB II, just for lerning...>>Buy the way, working with Resorcinol did not make me happy, to complicated>to get a perfect bond, and the risk of not being well done is still there...>certified or not.>>Saludos>>Gary Gower>>________________________________________________________________________________
Posted: Fri Aug 27, 1999 11:18 pm
I think Allen Rudoff's plane is put together withcasein glue. Its not hanging in a museum its flying.Ted.T________________________________________________________________________________
Posted: Sun Aug 29, 1999 8:48 pm
Original Posted By: Randy Gaskins
Russell,Have you researched the Titebond Polyurethane glue which is listed as beingwaterproof? You can go to their website and find some info on it - but it doesn'tsay how it compares to Titebond II strengthwise. It does claim, however, that itis "twice as thick as other polyurethanes" and is "unaffected by finishes." Goodluck on your Piet.Jim________________________________________________________________________________
Posted: Mon Aug 30, 1999 9:48 am
> I think Allen Rudoff's plane is put together with>casein glue. Its not hanging in a museum its flying.Ted.T>>Point in favor, if the glue holds better than the breaking point of thewood and is waterproff (even with the "help" of the barnish) is a good glue.It is still possible to find Casein Glue? Will like to know if someone usesit for any project, even is its not an airplane...SaludosGary Gower ________________________________________________________________________________
Posted: Mon Aug 30, 1999 11:14 am
Casein glue was used for years and has worked well in most applications.It is however made from dairy products and is suseptible under extremeconditions to being eaten by microbes. During WW II, a DeHavilandMosquito or two fell apart in the hot and very humid jungles of Borneobecause the glue had been eaten away. This is why resorcinal glue wasdeveloped. There are much better glues than casein out there, but here inNorth America there should be no difficulties with its service life undernormal conditions.John Langston writes:>> I think Allen Rudoff's plane is put together with>>casein glue. Its not hanging in a museum its flying.Ted.T>>>>>>>>Point in favor, if the glue holds better than the breaking point of >the>wood and is waterproff (even with the "help" of the barnish) is a good >glue.>>It is still possible to find Casein Glue? Will like to know if >someone uses>it for any project, even is its not an airplane...>>Saludos>>Gary Gower >__________________________________________________________________________________________
Pietenpol-List:
Posted: Wed Sep 01, 1999 9:53 pm
looking for the pros and cons or criteria in chosingbetween the long fuse or short. Is William wynn fromflorida a good source for corvair engines and techadvice?________________________________________________________________________________
Posted: Thu Sep 23, 1999 7:09 am
Walt- I was skeptical about the use of this glue also untilrecently a local industrial arts teacher built up his laminatedFly Baby wood gear, but first testing pieces glued up aftersoaking them in water for a week. (this is without varnish too)His physical testing (vise and hammer) proved the glue to holdperfectly with the wood breaking first as we like to see. ________________________________________________________________________________
