Pietenpol-List: Don't say that!!!
Posted: Wed Sep 01, 1999 1:17 am
In a message dated 8/31/99 11:51:18 PM Central Daylight Time, ronr(at)onlinemac.com writes:>Ron, I think Douglas Fir is a fine choice for for rib capstrip material. However, I have to say...I kind of cringe when I hear anyone adopt the notion that a little additional weight here or there will be ok since you'll have a little more power. I am a strong believer in the philosophy that weight should one of the foremost considerations in every component that goes into an airplane. You may be talking just a few ounces here and a few there..and before you blink you've got 16 ounces..then..more and more. I look at it as though there will come a day when I want to get out of a certain airport and I will appreciate the few pounds that I saved in the construction of the plane. One of those days when its hot, perhaps I over ate for lunch, and my passenger just bought some airplane part he couldn't do without to carry home. It is on those days that you suddenly rethink your confidence in your extra horsepower as the pine trees are looming taller and taller as you approach them in ground effect. Sorry...don't mean to preach to the choir. As for Douglas Fir for capstrip material, I have some data to pass on and I have an opinion to pass along for what it is worth. First, the data....you should expect a Douglas Fir rib to weigh in the neighborhood of 11 or 12 ounces. I have a Douglas Fir rib that I built as a "first-off" part when I made my rib jig. It is strictly dimensioned to the plans in the 1932 flying and Glider Manual. Recently I compared it with one of Chuck Gantzer's Red Cedar ribs and found mine to be almost 4.5 ounces heavier. His cedar ribs all averaged around 7.8 ounces or so. So the bottom line is...the difference in a wing with Douglas Fir ribs and an identical one with cedar ribs comes out to about 8.5 pounds. Now for my opinion. Red Cedar or Spruce is the way to go with Ribs. I have chosen to go with Cedar after reading what others have posted about it and after seeing Chuck G's wing. I have always felt that the 1/4 X 1/2 cross section for rib capstrips and bracing is a little on the over-engineered side. Thats not based on anything more than a feeling I get when I look at the Pietenpol wing as compared to various other wings of bigger and faster type certified airplanes (like wacos etc..) which have much smaller rib material cross-section. The Cedar isn't quite as strong as Spruce, but is just about the same weight. The sacrifice in strength to me is justified as I feel the ribs are over-designed to start with. And the much lower cost of the cedar really makes it the best choice in my opinion. I recently bought eight 2" X 4" X 12' boards for just under $50. This is enough material to make 2 shipsets of ribs. I hand selected these from a local Lumber supply place thats having a going out of business sale. Many of the boards I rejected were knotty...but with some diligent searching I was able locate some beautiful boards cut in the right direction with nice straight vertical grain. For some further data on the strength of the Western Red Cedar ribs...refer below to a previous email post by Mike Cushway from a few weeks back. Anyway..thats all I have for now. Keep it light!!!! Terry "always has an opinion" BowdenSubj: Re: RIB TESTING RESULTSDate: 8/21/99 5:07:52 PM Central Daylight Time________________________________________________________________________________
