Pietenpol-List: Re: Shoulder Harnesses
Posted: Mon Aug 02, 1999 4:32 am
Original Posted By: Sayre, William G
The shoulder harness issue is very simple, the big auto manufactureshave them so they must be good. This being the results of thousands ofcrash test. How about building a small support structure above theturtle deck, attaching the seat belt and transcending down at an angleabove the shoulder its when the belt loops up and over the shoulderfrom behind that the body moves forward and is compressed!Russell----- Original Message -----________________________________________________________________________________
Shoulder Harnesses
Posted: Sun Sep 12, 1999 7:08 am
Subject: Shoulder Harnesses One of the subjects that I'm very interested in right now isshoulder harnesses in Piets. I saw two different examples at Benton and I'm wondering whateveryone else has done? This is a subject that I hadn't worried about until now and I wentback over all my Piet pictures and couldn't find a single picture ofsomeone's installation. One of the installations was through a raised turtle deck(Joe Becks)and the other was going to be through a fiberglass head rest(ChuckGantzer). Unfortunately my digital camera didn't take good pictures ofeither one of these.(bad lighting) I hope my 35mm did. I haven't finished glueing my turtle deck down yet and I'mconsidering raising it so I can run my straps through it and back to mysturn post. I'm also concerned with attaching the shoulder harness anywhereexcept the sturn post. Anybody want to comment? Thanks, Greg Yotz________________________________________________________________________________
Pietenpol-List: Shoulder Harnesses
Posted: Sun Sep 12, 1999 11:04 am
One of the subjects that I'm very interested in right now is shoulderharnesses in Piets.I saw two different examples at Benton and I'm wondering what everyoneelse has done?This is a subject that I hadn't worried about until now and I went backover all my Piet pictures and couldn't find a single picture ofsomeone's installation.One of the installations was through a raised turtle deck(Joe Becks) andthe other was going to be through a fiberglass head rest(Chuck Gantzer). Unfortunately my digital camera didn't take good pictures of either oneof these.(bad lighting) I hope my 35mm did.I haven't finished glueing my turtle deck down yet and I'm consideringraising it so I can run my straps through it and back to my sturn post.I'm also concerned with attaching the shoulder harness anywhere exceptthe sturn post. Anybody want to comment?Thanks,Greg YotzOne of the subjects that I'm veryinterested inright now is shoulder harnesses in Piets.I saw two different examples atBenton and I'mwondering what everyone else has done?This is a subject that I hadn'tworried aboutuntil now and I went back over all my Piet pictures and couldn't find asinglepicture of someone's installation.One of the installations was through a raised turtledeck(JoeBecks) and the other was going to be through a fiberglass headrest(ChuckGantzer). Unfortunately my digital camera didn't take goodpictures ofeither one of these.(bad lighting) I hope my 35mmdid.I haven't finished glueing my turtledeck downyet and I'm considering raising it so I can run my straps through it andback tomy sturn post.I'm also concerned with attachingthe shoulderharness anywhere except the sturn post. Anybody want tocomment?Thanks,Greg Yotz________________________________________________________________________________
Posted: Sun Sep 12, 1999 11:24 am
Original Posted By: Greg Yotz
One thought that I can add to this, that I learned from the pros. Theshoulder straps should go up your chest, over the shoulder, and STRAIGHTIN, as much as possible, to the bulkhead. If not , in the event ofaccident, your body goes forward, and the spine compresses.Not a pretty thought.waltps My Fisher's shoulder harness attached to tailwheel fitting at thesternpost. -----Original Message-----
Posted: Sun Sep 12, 1999 7:45 pm
Greg,If you install shoulder straps MAKE SURE that they fasten several inches above your shoulders!DO NOT fasten them lower! Doing so will virtually guarantee a broken back in any sort of impact. Den________________________________________________________________________________
Posted: Sun Sep 12, 1999 11:11 pm
Original Posted By: Howard Wilkinson
Subject: Pietenpol-List: Re: Shoulder Harnesses>There was a article in Sport Aviation several years ago aboutshoulder>harnesses. It was written by a doctor and he told of how these overthe>shoulder from below harnesses will compress and even break your backin>case of sudden stoppage. We don't plan on installing them in ourplane.>John Langston>________________________________________________________________________________
Posted: Mon Sep 13, 1999 6:04 pm
There was a article in Sport Aviation several years ago about shoulderharnesses. It was written by a doctor and he told of how these over theshoulder from below harnesses will compress and even break your back incase of sudden stoppage. We don't plan on installing them in our plane.John Langston__________________________________________________________________________________________
Posted: Tue Sep 14, 1999 8:03 pm
Good thinking
...... You may die of internal injuries... rupturedbladder & spleen, etc...., but at least your back won't be broken!!!It is foolish in the extreme to dispense with sholder harnesses forfear of a broken back. Seat belt alone will cause grevious internalinjuries in case of a violent stoppage.... the sholder harness willprevent this. The correct approach is to design a sholder harnessinstallation which will not result in compression of the spine. Acompression strut(s) (vertical) could prevent this problem and allowyour strap to fasten low. This reminds me of the people who refuse towear a seat belt because they know of someone who burned to deathtrapped by their seat belt...... without consideration for all thosewho were thrown from the vehicle and killed due to not being strappedin. I use a full 4 point racing harness available from your localspeed shop for about $ 75.00 in either a double seperate sholderharness system, or a system where both sholder harnesses are sewntogether with a single strap passing to the rear. I use the lattersystem. This isn't in a Piet however.H.W.-----Original Message-----
Posted: Wed Sep 15, 1999 12:14 am
Subject: Pietenpol-List: Re: Shoulder Harnesses>H W>I started this discussion about the shoulder harness " back squish".Only>wanted to inject a thought given to me by my mentor that enlightenedme to>a fact that I hadn't thought of. Didn't mean do it my way or not atall.>Just meant if you have a choice, put the straps straight back from>shoulders( or flatter the better).>walt>-----Original Message----->From: Howard Wilkinson >To: Pietenpol Discussion >Date: Wednesday, September 15, 1999 12:00 AM>Subject: Re: Shoulder Harnesses>>>>Good thinking
...... You may die of internal injuries...ruptured>>bladder & spleen, etc...., but at least your back won't be broken!!!>>It is foolish in the extreme to dispense with sholder harnesses for>>fear of a broken back. Seat belt alone will cause grevious internal>>injuries in case of a violent stoppage.... the sholder harness will>>prevent this. The correct approach is to design a sholder harness>>installation which will not result in compression of the spine. A>>compression strut(s) (vertical) could prevent this problem and allow>>your strap to fasten low. This reminds me of the people who refuseto>>wear a seat belt because they know of someone who burned to death>>trapped by their seat belt...... without consideration for all those>>who were thrown from the vehicle and killed due to not beingstrapped>>in.>> I use a full 4 point racing harness available from your local>>speed shop for about $ 75.00 in either a double seperate sholder>>harness system, or a system where both sholder harnesses are sewn>>together with a single strap passing to the rear. I use the latter>>system. This isn't in a Piet however.>>>>H.W.>>>>-----Original Message----->>From: nle97(at)juno.com >>To: Pietenpol Discussion >>Date: Monday, September 13, 1999 4:11 PM>>Subject: Re: Shoulder Harnesses>>>>>>>There was a article in Sport Aviation several years ago about>>shoulder>>>harnesses. It was written by a doctor and he told of how these over>>the>>>shoulder from below harnesses will compress and even break yourback>>in>>>case of sudden stoppage. We don't plan on installing them in our>>plane.>>>John Langston>>>>>>>>>________________________________________________________________________________
Posted: Wed Sep 15, 1999 7:00 am
Subject: Pietenpol-List: Re: Shoulder Harnesses>Good thinking
...... You may die of internal injuries... ruptured>bladder & spleen, etc...., but at least your back won't be broken!!!>It is foolish in the extreme to dispense with sholder harnesses for>fear of a broken back. Seat belt alone will cause grevious internal>injuries in case of a violent stoppage.... the sholder harness will>prevent this. The correct approach is to design a sholder harness>installation which will not result in compression of the spine. A>compression strut(s) (vertical) could prevent this problem and allow>your strap to fasten low. This reminds me of the people who refuse to>wear a seat belt because they know of someone who burned to death>trapped by their seat belt...... without consideration for all those>who were thrown from the vehicle and killed due to not being strapped>in.> I use a full 4 point racing harness available from your local>speed shop for about $ 75.00 in either a double seperate sholder>harness system, or a system where both sholder harnesses are sewn>together with a single strap passing to the rear. I use the latter>system. This isn't in a Piet however.>>H.W.>>-----Original Message----->From: nle97(at)juno.com >To: Pietenpol Discussion >Date: Monday, September 13, 1999 4:11 PM>Subject: Re: Shoulder Harnesses>>>>There was a article in Sport Aviation several years ago about>shoulder>>harnesses. It was written by a doctor and he told of how these over>the>>shoulder from below harnesses will compress and even break your back>in>>case of sudden stoppage. We don't plan on installing them in our>plane.>>John Langston>>>>________________________________________________________________________________
Pietenpol-List: RE: Shoulder Harnesses
Posted: Wed Sep 15, 1999 2:59 pm
Original Posted By:> Ian Holland[SMTP:
iholland@microage-tb.com]
I can GUARANTEE that shoulder a harness can save your life. I witnessed a Pietenpolaccident where the passenger elected not to wear his shoulder harness andhe died of massive head injuries. Pilot wearing shoulder harness survived.We're right to be concerned about back/spine compression injuries, but at leastyou'll be alive for the treatment! (My 2 cents)Bill Sayre> ----------
Posted: Wed Sep 15, 1999 5:38 pm
You may want to sit in the Piet cockpit, and look at how close your faceis to the panel. The cracked back may be better than the fracturedskull. It seems to me that when i joined the EAA way back, I had tosign a form stating that I would install shoulder restraints in anyamateur built plane that I did. Must be a reason!It might look funny, but has anyone put a post up just aft of the seatback?I still don't know what to do with the shoulder strap attach point, butwhen I sit there and lean forward, I know its going to be worse than aface plant in skiing!________________________________________________________________________________
Pietenpol-List: Re: center section cabane strut brackets:
Posted: Wed Sep 15, 1999 7:07 pm
Original Posted By:> Leon Stefan
Do the later,welds in tension are not a good idea,the u shaped idea issafer,if your edge weld fails,nothing will depart,this is good. Doug
Posted: Wed Sep 15, 1999 7:11 pm
H WI started this discussion about the shoulder harness " back squish". Onlywanted to inject a thought given to me by my mentor that enlightened me toa fact that I hadn't thought of. Didn't mean do it my way or not at all.Just meant if you have a choice, put the straps straight back fromshoulders( or flatter the better).walt-----Original Message-----
Posted: Wed Sep 15, 1999 8:10 pm
Original Posted By: Doug
x-mac-creator="4D4F5353"How have some of you been attaching the shoulder harness for the frontseat to the fuselage? If I attach though the the back of seat it anglesdown too much. Can't lower the seat because I have the master cylindersfor the brakes under there.Craig________________________________________________________________________________
Posted: Wed Sep 15, 1999 10:26 pm
Walter: My comment was not directed at you in any way.... John Langstoncommented: " We don't plan on installing them in our plane." Aftermentioning the problem of spinal compression. The implication beingthat out of concern about spinal compression it was decided not to usea shoulder harness. Perhaps John feels that sudden death by violent head injury orinternal injuries is preferable to life as a quadriplegic. If so Ican relate to that concern..... I almost left off my crotch strap frommy 5 point harness out of similar concerns. However in the case of the shoulder harness proper design willprevent either eventuality....... (head injury or spinal injury). In the case of my crotch strap, at age 44, I'm perhaps past mysexual prime, and if I were to suffer damage as a result of thatstrap, I could look on the bright side of things and see that it wouldsimply leave me with more time for other activities such as flying.
Posted: Thu Sep 16, 1999 7:00 am
Original Posted By:> > Ian Holland[SMTP:
how did this accident happen. when I hear of anaccident I like to know why, to help me to avoid thatsituation.---"Sayre, William G" wrote:>> I can GUARANTEE that shoulder a harness can saveyour life. I witnessed a Pietenpol accident wherethe passenger elected not to wear his shoulderharness and he died of massive head injuries. Pilotwearing shoulder harness survived.> > We're right to be concerned about back/spinecompression injuries, but at least you'll be alivefor the treatment! (My 2 cents)> > Bill Sayre> > ----------
Posted: Thu Sep 16, 1999 7:58 am
Original Posted By:> del magsam[SMTP:farmerdel(at)rocketmail.com]
Stall/spin after downwind takeoff and during downwind turn.> ----------
Pietenpol-List: Cabane strut fittings:
Posted: Thu Sep 16, 1999 8:26 am
Walter & Doug: Thanks for the tip's. I guess I will scrap my plans-builtbrackets and build new ones.Someone wrote"I do not have a proper set ofPiet plans"... I do and they are not "proper". It's hard to believe thatBHP. and O. Hoopman, for as good as they were, never took the time tore-draw a set of debugged plans. Leon S.________________________________________________________________________________
Posted: Thu Sep 16, 1999 10:19 am
I made the fittings using two u-shaped brackets. Mostly because I don'ttrust my welding enough to depend on them to hold up the plane.Do the math on these fittings and you will see just how overbuilt aPietenpol is. Incredible!Greg Cardinal>>> Leon Stefan 09/15 5:31 PM >>>The plans for the upper cabane spar fittings as "U" channel made of 3/4X .90 strap, with 2 tab's welded below for the top of the cabane strut.Several people are telling that is wrong. Need to be 2 "U" channelswelded together at crotch, one facing up the other down. What have youother builders done? Leon S.________________________________________________________________________________
Pietenpol-List: RE: CG and Trim
Posted: Wed Sep 22, 1999 9:54 pm
Original Posted By:> > Maiser(at)adena.byu.edu
Drill a hole in the seat.Use a bycycle bungee cord.JimV.--- steve(at)byu.edu wrote:> Re Trim tabs:> > I used a bungee fastened to my belt on my flight> back home from Brodhead.> All I needed was about 1.5 pounds of pull (maybe> less) but it made a great> difference after nearly 20 hours of flying. around> home I don't use> anything.> > Steve Eldredge> IT Services> Brigham Young University> > > > -----Original Message-----
Posted: Thu Sep 23, 1999 12:42 am
Original Posted By: Jim VanDervort
In a message dated 9/21/99 2:59:40 PM Central Daylight Time, rrobert(at)centuryinter.net writes:>I'm using a headrest above the turtle deck tapering back just beyond the next former. I made the form using blue foam and hot wire. The harness will carry thru the headrest, attach to a cable, and the cable is attached to the tailpost.Chuck G________________________________________________________________________________
> > The plans for the upper cabane spar fittings as "U" channel made of 3/4> X .90 strap, with 2 tab's welded below for the top of the cabane strut.> Several people are telling that is wrong. Need to be 2 "U" channels> welded together at crotch, one facing up the other down. What have you> other builders done? Leon S.> ________________________________________________________________________________
