Pietenpol-List: 3/4" spars
Posted: Sun Sep 12, 1999 2:23 pm
Wayne wrote:snip>My spars & Ed Snyders' are both 3/4".Our ribs have both uprights for the spar. I made the ribs with a oneinch space between the fwd & aft upright. That gave me plenty of room toslide the ribs unto the spar. After the ribs were located a 1/4" plywoodspacer was place on the after face of the spar at each rib location.Mike B Piet N687MB ( Mr Sam )Wayne wrote:snip I have seen severalreferencesto 3/4 spars My spars Ed Snyders'are both 3/4.Our ribs have both uprights for the spar. Imade theribs with a one inch space between the fwd aft upright. That gavemeplenty of room to slide the ribs unto the spar. After the ribs werelocated a1/4 plywood spacer was place on the after face of the spar at eachriblocation.Mike B Piet N687MB ( Mr Sam)________________________________________________________________________________
Re: Pietenpol-List: 3/4" spars
Posted: Fri Sep 01, 2000 2:12 am
Original Posted By: mb-albany(at)att.net
Subject: Re: Pietenpol-List: 3/4" spars>>>>>>My spars and other wing material arrived today from Jean Peters.>>However, the spars are 3/4", not 1" as per the plans. My ribs are all>>sized for 1" spars. I have yet to hear back from him about it, but has>>anyone else used a 3/4" spar and [1/4" fillers?] on their wing? Am I>>missing a point somewhere?>>>>>Hey Dick:>You aint missing much. My Piet & Ed Snyders' two Piets & his Sky Scout have>3/4 in spars. We just put 1/4 X 1/2 in inserts on the back side of the spar>at ech rib location. Don't sweat it. it works.>>Mike B Piet N687MB ( Mr Sam )>>________________________________________________________________________________
Original Posted By: Flite407(at)aol.com
Posted: Fri Sep 01, 2000 2:58 pm
Original Posted By: "Domenico Bellissimo"
In regard to the message from the fellow that received 3/4" spars , I'veheard before that they are OK ( I used 3/4" Doug Fir), but since the ribsare already made with a space for 1" spars, rather than block out the ribs,why not glue a piece of 1/4" by 3/4" spruce to the top and bottom of oneside of each spar to create a I beam effect without routing. That wouldgive most of the strength of 1" spars with a little less weight and it wouldprobably be easier than blocking all the individual ribs. You might alsowant to block out at the lift strut attach points and the wing attach pointsto keep the attachments in accordance with the plans. Joe Kohler________________________________________________________________________________
Posted: Fri Sep 01, 2000 5:18 pm
Original Posted By: Microcar2(at)aol.com
"Domenico Bellissimo" That's a good idea, except I would glue 1" X 1/8" to both sides. It's reallyonly the top and bottom inch that gives all of the strength in an "I-beam"spar.regards,Domenico________________________________________________________________________________
Fw: Pietenpol-List: 3/4" spars
Posted: Sat Sep 02, 2000 8:19 am
"Michael Brusilow" -----Original Message-----
Posted: Sat Sep 02, 2000 8:24 am
---------------------- Forwarded Message: ---------------------
Posted: Fri Feb 16, 2001 6:35 pm
Original Posted By: "John or Jean Dilatush"
>I used 1" spars. I have had no problems.>Mike B Piet N687MB ( Mr Sam )Correction: 3/4" spars.Mike B________________________________________________________________________________
