Pietenpol-List: BOX SPAR CONSTRUCTION
Posted: Wed Sep 15, 1999 7:16 am
Subject: Pietenpol-List: BOX SPAR CONSTRUCTION>For those of you who have experience with built-up spars, I have a few>questions.>> 1) What are the H & W dims of the caps?> 2) Does grain orientation matter on the plywood faces?> 3) Does grain orientation matter on the caps?> 4) Did you truss or bridge the interior?> 5) Do you internally reinforce the attach points?> 6) Assuming a finished spar of 1"width, are ribs attached in the > same manner as a solid spar?>>>Mike Cushway> Mfg. Engineering> >>________________________________________________________________________________
