Pietenpol-List: Shoulder Harnesses (front pit routing)
Posted: Wed Sep 15, 1999 5:20 am
Original Posted By: oil can
Subject: Pietenpol-List: Shoulder Harnesses (front pit routing)>The compression issue can obviously be overcome by a compression>strut(s).....In this case the fuselage structure itself could serve>this purpose. There remains the issue of how to attach the harness in>the front pit without a steep downward angle. The obvious answer to>this is to have a sturdy structure directly behind the passenger to>carry the load outward to the longerons.... The structure between the>pits could be built sturdily enough to serve this purpose. A>laminated arch covered with light ply and integrating with the cross>piece at station 41.5, behind the front pit, supporting the section of>turtle deck between the pits, and plywood covering between the rear of>the front pit and the front of the rear pit and other strategic places>with a good structure behind the instrument panel could serve the>purpose.That's the way the Moth does it! by the way Bernard mentions copying theDeHavilland fuselage in his article in the Flying and Glider manual.J Mc________________________________________________________________________________
