Pietenpol-List: Re: Fw: questions(2)
Posted: Wed Sep 29, 1999 9:34 pm
Original Posted By: oil can
Oh...and as for the 2nd part of your question.....Douglas Fir is what I plan to use for my spars.... In keeping with the way several other Piet builders have done, I am dropping the thickness from 1 inch routed spruce to 3/4 inch solid Douglas Fir....I still use the same wing hardware dimensions but use plywood doublers to fill out to 1 inch in the attach fitting areas. This also requires use of 1/8th inch shims at each rib (if you are using upright braces next to the spars)......Terry B________________________________________________________________________________
Pietenpol-List: Re: CG and Trim
Posted: Wed Sep 29, 1999 9:42 pm
I have a rudder trim tab, but it is manually done by bending while on theground.Ted BNaples, FL----- Original Message -----________________________________________________________________________________
Posted: Wed Sep 29, 1999 10:17 pm
Im not speaking from experience, butfrom differentdiscussions I have read in this group. keeping theweight off is a very important,widely excepted, truth.and by using spruce versus douglass fir is one way ofkeeping weight off. I should be recieving my spruceanyday from mccormick lumber,madison wi. all thespruce I need for the piet was $389.00. At that price,would you be saving any more money buying douglassfir?--- BARNSTMR(at)aol.com wrote:> Oh...and as for the 2nd part of your> question.....Douglas Fir is what I plan > to use for my spars.... In keeping with the way> several other Piet builders > have done, I am dropping the thickness from 1 inch> routed spruce to 3/4 inch > solid Douglas Fir....I still use the same wing> hardware dimensions but use > plywood doublers to fill out to 1 inch in the attach> fitting areas. This > also requires use of 1/8th inch shims at each rib> (if you are using upright > braces next to the spars)......Terry B> ________________________________________________________________________________
