Pietenpol-List: Burnt props and grade 5 bolts.
Posted: Sat Oct 02, 1999 5:50 am
Subject: Pietenpol-List: Burnt props and grade 5 bolts.Haven't we seen this before?The Volkswagen engined guys have had this problem for years. They havelost a few props too. If they don't keep their prop bolts tight, thesurface against the driving flange will char because of the frictioncaused by movement between the prop and flange..Grade 5 bolts!!!! That's common, autoparts store stuff. I thought thatthe word had gotten to everyone about using aircraft (AN) hardware inall structural applications in homebuilts, regardless of what the 1930splans say. Certainly the prop bolts are the most structural fastener inthe whole plane. There are wonderful aircraft propeller bolts availiablefor all dimensions with fine threads, drilled heads for safety wire andhuge strength.I am afraid that I would want to look over the rest of the plane and seeif the lift and cabane strut attach fittings, the wire attach fittings,etc. had correct AN fasteners.I wonder what the FAA inspector looked at on this aircraft if he didn'tlook at the type of fasteners being used. A first time builder, whohasn't been following the literature for 20 years can be forgiven amistake like this. What is the inspector's excuse?I am building a Pietenpol so that I can experience and share theadventures of the early day aviators. I really have no intrest inreexperiancing their "misadventures".I guess this got me excited!Lauren________________________________________________________________________________
