Pietenpol-List: foam filled fuel tanks
Posted: Fri Oct 08, 1999 9:41 am
Original Posted By: "Conrad, Bart D"
I recieved a catalog from "ATL racing fuel cells" theyhave molded plastic fuel cells that are foam filled(to prevent explosion and fire in the event of acrash)that weigh 18 lbs in a 12 gal size. and the cost is$311.00 and has a 5 year limited warranty. It can alsobe fitted with a spill proof filler in the case ofoverturn. another option is to build your own aluminumtank around their foam. the cost for just the foam is53.00 for a 12 gal size. what is everybodys thoughts on that and how does thatweight compare to a conventional aluminum tank?del=====________________________________________________________________________________
