> Rib clearance on Rear Spar
Posted: Wed Oct 13, 1999 8:51 am
Gary, I think the bevel of the rear spar is due to the inside dimension of the spar area of the capstrip is 4 3/4", but the aft dimension is slightly less! This means that you don't need a wedge, you need to actually bevel the top of the rear spar. I've even considered trimming the spar height by the difference and using wedges, but leaning toward beveling the whole spar. Whichever way I go, I plan on including pieces on the rib jig to represent the spars to insure fit.Joe>From: Gary Meadows >Reply-To: Pietenpol Discussion >To: Pietenpol Discussion >Subject: Rib clearance on Rear Spar>Date: Tue, 12 Oct 1999 21:13:45 -0700 (PDT)>>Well, I've finally actually started doing something constructive on my Piet>Project! I am working on the rib jig, and have the template laid out, and>all my blocks cut and drilled.>> At the risk of bothering those who may have already seen this discussed>over and over, I'm gonna raise the issue again. In laying out my jig, I>noticed the area where the top of the rear spar and the top capstrip meet>there should be a tiny wedge, but on the template, the spar is shown with a>slight bevel.>> I think some folks make up the rib and just remove some capstrip to make>it fit the squared spar, but I was wondering about just pushing the rear>spar down enough to make room for the wedge, thus moving the lower strip>down the same amount. I haven't measured it all out, but I get the feeling>that the lower capstrip may have not been positioned correctly on the>template, so It seems as though this would all work out.>> Gordon: It sounds as though about all that's needed for the ListBot>service then, is someone to get the thing setup and then it pretty much >runs>on autopilot? I guess I could do that, I'm sure I'll be around for a LONG>time, heck it's gonna take enough time just to get the rib jig together! If>it's low, and I mean LOW maintenance, then it wouldn't be too much of a>hassle, I guess......>>Gary Meadows>>________________________________________________________________________________
