Re: Pietenpol-List: cockpit heat
Posted: Thu Dec 09, 1999 3:21 am
Original Posted By: StOrMiN3(at)aol.com
Subject: Re: Pietenpol-List: cockpit heat>>del magsam wrote:>> >> >> >> Does anybody have any ideas or sketches on how to>> route the engine heat into the cockpits to stretch the>> flying season? I can envision a flapper door at the>> bottom of the firewall that closes the normal heat>> outlet and reroutes it into the cockpit.>> thanks>> del>>Hi Del>You may want to look at VAN'S Aircraft parts catalog. They have>a heat valve that mounts on/through the fire wall. Use Scat tubing>from the heat muff to the valve and again from the valve on the inside>of the cockpit to were the heat will do the mout good.>I limit my flying to 65 degrees.>Rich>81ET>>________________________________________________________________________________
Pietenpol-List: AS&S Online Ordering
Posted: Thu Dec 09, 1999 2:33 pm
Original Posted By: Rich
Pietenpoler's Yesterday I had an interesting experience with Spruce's online ordering through the Web that I thought I'd share with everyone. Some folks are into ordering online so this is for y'all. I went to order some wood, glue, and tubing from AS&S, and got all my part numbers in, amounts needed, and the online ordering software had calculated all my prices and total. I reviewed it, put in my card number, and hit submit, and Spruce's website replied back that there were errors in my order, SO I needed to review it, correct it, and resubmit. Okay, So I tried it again, again, again, and again. I finally gave up and figured I'd phone order it the next day. When I logged on to check email last night, I was greeted by 5 order confirmations! All the orders HAD been placed! It was no big deal, I called them this morning, and a nice lady there helped me to work through it all, and reduce my order to just one. She did think it was pretty funny, though, me too once it was worked out! I did tell them I think they have a software glitch. Maybe Y2K early! So, if you order from AS&S online, and get an error message, stop there! You may have already placed your order!Gary Meadows________________________________________________________________________________Date: Thu, 09 Dec 1999 20:10:01 -0600
Posted: Thu Dec 09, 1999 9:13 pm
Re: Pietenpol-List: Ref: Cockpit heater
Posted: Thu Dec 09, 1999 10:22 pm
Del, you could do what the snowmobilers up here do in the winter.Add a snowmobile suite, boots mitts, helmet and face shield. Ihave done 2 hours solid at 70 mph on lake of the woods at -36Cbefore I started to feel the cold. The Piet with almost fullenclosure and proper widscreen will give the rider moreprotection than a snow machine does.For what it's worth....-=Ian=------ Original Message -----
Posted: Thu Dec 09, 1999 10:32 pm
Del:If all else fails.....You COULD move down here to Florida. Huh?;>)All the Best, Bert(There's always one in any crowd.... and I'm usually it!)-----Original Message-----
