Re: Pietenpol-List: Drag/Antidrag wires-Cables???
Posted: Sat Jan 01, 2000 8:27 pm
Original Posted By: "Tim Cunningham"
Tim, What about cables with turnbuckles? I would guess that thedrag/antidrag forces in the wing would be well under the tensil strengths ofsay 1/8 th inch cables. Of Course you have to deal with buying severalturnbuckles, huh? Wonder how the tensil capacities for cable stack upagainst that of threaded rod? Hmmm. might have to check on this more.What about it? any of you out there got an opinion? I'm not an A>)Thanks, Bert----- Original Message -----
Posted: Sat Jan 01, 2000 9:04 pm
Original Posted By:> Conoly
I used 4 bays in each wing of 3/16 1020,fabed up angled fittings foradjustment.Turn buckles deadly $. Doug----------
Posted: Sat Jan 01, 2000 9:13 pm
Original Posted By:> > Conoly
Subject: Re: Pietenpol-List: Drag/Antidrag wires-Cables???Could you go a little farther in your explaination? 3/16th what and 1020what.Steve> > I used 4 bays in each wing of 3/16 1020,fabed up angled fittings > for> adjustment.Turn buckles deadly $.> Doug> > > ----------
Posted: Sat Jan 01, 2000 10:03 pm
Original Posted By: "Doug"
Yeah, but Doug....If you're talking about 1020 steel rods with two tie rod ends at 10 buckseach, arent you still pretty much in the same ball park dolar-wise with onestrand of steel cable and a 16.00 turnbuckle. Just asking......Also how hard is it to thread these things. I've never tried to thread rodbefore. I know cable is easy to rig.Just asking.Thanks, Bert----- Original Message -----
Posted: Sat Jan 01, 2000 10:55 pm
Original Posted By: "Conoly"
Subject: Re: Pietenpol-List: Drag/Antidrag wires-Cables???1020 mild steel rod is VERY easy thread. ________________________________________________________________________________
Posted: Sun Jan 02, 2000 11:46 am
Original Posted By:> vistin(at)juno.com
Steve; 1020 is the type or alloy of the steel 3/16 being the diameter (.1875thou).Lauren Williams described the install nicely.Doug Hunt.....----------
Posted: Sun Jan 02, 2000 11:53 am
Hi Bert; Did not use any tie rod ends.Read Lauren Williams post on the installdetails.Rods are simple to thread.I used 4 bays in each wing panel,notsaying that is the way you should do it,but is the way i did. Doug Hunt----------
Posted: Mon Jan 03, 2000 5:47 pm
Original Posted By: Star449190(at)aol.com
Subject: Re: Pietenpol-List: Drag/Antidrag wires-Cables???please atke me of of your mailing lists , i have no idea whaT THIS IS ________________________________________________________________________________
Posted: Mon Jan 03, 2000 8:20 pm
Subject: Re: Pietenpol-List: Drag/Antidrag wires-Cables???take me off of your mailing list i didn't sign up for anything________________________________________________________________________________Date: Tue, 04 Jan 2000 09:03:45 -0600
Posted: Thu Jan 06, 2000 7:20 pm
Original Posted By: COZYPILOT(at)aol.com
Subject: Re: Pietenpol-List: Drag/Antidrag wires-Cables???you can unsubscribe yourself by using the address at the bottom http://www.matronics.com/subscribe.____ ... __________
Original Posted By:> "Tim Cunningham"
> > > Tim, What about cables with turnbuckles? I would guess that the> drag/antidrag forces in the wing would be well under the tensil strengthsof> say 1/8 th inch cables. Of Course you have to deal with buying several> turnbuckles, huh? Wonder how the tensil capacities for cable stack up> against that of threaded rod? Hmmm. might have to check on this more.> > What about it? any of you out there got an opinion?> > I'm not an A>)> Thanks, Bert> > > ----- Original Message -----
Original Posted By:> > "Tim Cunningham"
> > > > > > > Tim, What about cables with turnbuckles? I would guess that the> > drag/antidrag forces in the wing would be well under the tensil > strengths> of> > say 1/8 th inch cables. Of Course you have to deal with buying > several> > turnbuckles, huh? Wonder how the tensil capacities for cable > stack up> > against that of threaded rod? Hmmm. might have to check on this > more.> > > > What about it? any of you out there got an opinion?> > > > I'm not an A>)> > Thanks, Bert> > > > > > ----- Original Message -----
> >> >> > Tim, What about cables with turnbuckles? I would guess that the> > drag/antidrag forces in the wing would be well under the tensilstrengths> of> > say 1/8 th inch cables. Of Course you have to deal with buying several> > turnbuckles, huh? Wonder how the tensil capacities for cable stack up> > against that of threaded rod? Hmmm. might have to check on this more.> >> > What about it? any of you out there got an opinion?> >> > I'm not an A>)> > Thanks, Bert> >> >> > ----- Original Message -----
> > > Could you go a little farther in your explaination? 3/16th what and 1020> what.> ________________________________________________________________________________
> > > Yeah, but Doug....> > If you're talking about 1020 steel rods with two tie rod ends at 10 bucks> each, arent you still pretty much in the same ball park dolar-wise withone> strand of steel cable and a 16.00 turnbuckle. Just asking......> Also how hard is it to thread these things. I've never tried to threadrod> before. I know cable is easy to rig.> > Just asking.> Thanks, Bert> ________________________________________________________________________________
