Re: Pietenpol-List: C-FAUK (No, I am not swaering at anybody
Posted: Tue Jan 18, 2000 4:03 am
Original Posted By: "oil can"
Subject: Re: Pietenpol-List: C-FAUK (No, I am not swaering at anybody)>>Hi,>Try
bkenney@petro-canada.ca>I'm sure he already has the article. I'm not sure what his home e-mail>address is though.>>Domenic>>________________________________________________________________________________
> Pietenpol-List: welding
Posted: Tue Jan 18, 2000 10:04 pm
A year or so ago I read an article about an airplane called a Longster. The origonal way to build was not to weld the tubing at all. Instead, they built it with sheet steel gussets, brazed to the tubing.From what I hear, brazing is no longer acceptable for a/c use, because of a problem with dissimilar metals, and electric corrosion.If you silvar soder, you may run into the same problem, and a silve sodered part may not be considered air worthy.Just something to think about I really don't know.Bob>From: del magsam >Reply-To: pietenpol-list(at)matronics.com>To: piet aircamper >Subject: Pietenpol-List: welding>Date: Tue, 18 Jan 2000 04:50:39 -0800 (PST)>>> listening to the welding posts. I am hearing so>many different things that I'm still not absolutely>sure what is the best method, if there is a best>method.> so this is the tentitive conclusion that I've>arrived at. I've had a few parts wire feed welded and>they are soft enough to file. so they should be good,>so I'm not going to "normalize" them, which Is the>same as "annealing" (bringing back to a soft state). I>am purchasing the motor mt from william wynn so I>don't have to worry about that falling apart. some of>the real light guage metal work I plan to silver>solder.>comments?>>del>Talk to your friends online with Yahoo! Messenger.>http://im.yahoo.com>>________________________________________________________________________________
