Pietenpol-List: Steves gas tank.
Posted: Fri Feb 11, 2000 6:58 pm
Original Posted By: "Mike Lund"
Subject: Pietenpol-List: Steves gas tank.I want too know what kind of gas tamk Steve Eldrige used in his Piet. Isit in the front of the fuse or is it in the wing center section.SteveSteve W GN-1 builderIHA #6________________________________________________________________________________
RE: Pietenpol-List: Steves gas tank.
Posted: Mon Feb 14, 2000 9:46 am
My tank is .025 (I think) aluminum 3003 dead soft from a sheet metal ductingshop. the seams are pop riveted and prosealed. Used a chevy filler neckfrom the junk yard and an automotive cap from AutoZone. I modified the capby drilling through an attaching a six inch vent pointed forward. for afloat I designed a home made indicator that protrudes out the bottom. nextto a on/off valve. It is in the wing center section. So far so good. I'lltry my hand at welding my next one out of Al with a torch.Steve e.I think you will see som pics of my tank and indicator at:aircamper.byu.edu-----Original Message-----
