Pietenpol-List: PIET: a-65 to a-75
Posted: Wed Mar 29, 2000 3:33 am
Original Posted By: Borodent(at)aol.com
Subject: Pietenpol-List: PIET: a-65 to a-75>>Does anyone know the procedure to convert an A-65 to A-75?>Does a manual exist?>Any help at all?>>Barry Davis>bed(at)mindspring.com>>________________________________________________________________________________
Posted: Wed Mar 29, 2000 3:43 am
Original Posted By: JOEL CARROLL
Subject: Pietenpol-List: PIET: a-65 to a-75>>Does anyone know the procedure to convert an A-65 to A-75?>Does a manual exist?>Any help at all?>>Barry Davis>bed(at)mindspring.com>>________________________________________________________________________________Date: Thu, 30 Mar 2000 14:44:24 -0800 (PST)
Posted: Wed Mar 29, 2000 8:36 pm
Does anyone know the procedure to convert an A-65 to A-75?Does a manual exist?Any help at all?Barry Davisbed(at)mindspring.com________________________________________________________________________________
Re: Pietenpol-List: PIET: a-65 to a-75
Posted: Wed Mar 29, 2000 9:21 pm
Original Posted By:> Barry Davis
I think it is just different pistons.----------
Re: Pietenpol-List: Spar spacing
Posted: Wed Mar 29, 2000 10:30 pm
Original Posted By: "oil can"
Subject: Re: Pietenpol-List: Spar spacingIn a message dated 3/28/00 10:56:36 PM Central Standard Time, griffins(at)emji.net writes:>Jeff, I'm using the 'Improved Air Camper' plans and didn't have much trouble getting the ribs to fit the spar spacing. It was a tight fit, though. Don't alter the spacing of the spars, because this would alter the cabane struts, and the attachments to the fuselage, and the landing gear. Don't alter the height of the spar, either, as this will weaken the wing (ya just never know when ya might hit some turbulance), and don't noch the top cap strip on the ribs, either. This would cause a weak point in the rib. I think the best way is to alter your rib jig slightly, to accept the height of the spar.Chuck G.Wichita KSps See y'all at the Annual Pietenpol Fly-In, at Benton Airpark, on Saturday, Sept. 9________________________________________________________________________________
Posted: Wed Mar 29, 2000 11:25 pm
Original Posted By: "Greg Yotz"
As I recall, the difference between the A-65 and the A-75 was to change either the carb, or the jets, then run at a higher RPM.Bob>From: "Barry Davis" >Reply-To: pietenpol-list(at)matronics.com>To: "piet list" >Subject: Pietenpol-List: PIET: a-65 to a-75>Date: Wed, 29 Mar 2000 21:36:51 -0500>>>Does anyone know the procedure to convert an A-65 to A-75?>Does a manual exist?>Any help at all?>>Barry Davis>bed(at)mindspring.com>>________________________________________________________________________________
Posted: Wed Mar 29, 2000 11:54 pm
Original Posted By:>> Barry Davis
Subject: Re: Pietenpol-List: PIET: a-65 to a-75>>walt, your right. i looked it up and the only>difference in th 65 to 90 hp is con rods, compresion>ratio and hp quoted at rpm. what was the address of>that placve in CA? thanks jkc.>>--- walter evans wrote:>> >>>> Barry,>> I was told that the pistons are different, and you>> have to check the>> connecting rods for an oil hole in the rod bearing (>> where it rides on the>> crank). The newer ones had the hole, I guess, to>> take the added pounding.>> My mentor told me that if you have to replace>> pistons anyway, go for the>> 75's. But to throw away good 65 pistons and put in>> 75 pistons, that you>> won't see that much of a difference.>> I got all my Continental parts from a place in>> California. Can look up the>> name. They have a nice parts book covering the A65>> and A75. Giving>> complete dimensional drawings and weights also.>> Parts were reasonable and>> all in stock.>> my two cents>> walt>>>----------------------------------------------------->> Click here for Free Video!!>>
http://www.gohip.com/freevideo/>>>> -----Original Message-----
Posted: Thu Mar 30, 2000 1:59 pm
Original Posted By: Barry Davis
Barry,I was told that the pistons are different, and you have to check theconnecting rods for an oil hole in the rod bearing ( where it rides on thecrank). The newer ones had the hole, I guess, to take the added pounding.My mentor told me that if you have to replace pistons anyway, go for the75's. But to throw away good 65 pistons and put in 75 pistons, that youwon't see that much of a difference.I got all my Continental parts from a place in California. Can look up thename. They have a nice parts book covering the A65 and A75. Givingcomplete dimensional drawings and weights also. Parts were reasonable andall in stock.my two centswalt-----------------------------------------------------Click here for Free Video!!
http://www.gohip.com/freevideo/-----Original Message-----
Posted: Thu Mar 30, 2000 5:17 pm
Joel,It's Fresno Airparts co. , in California.209-237-4863 phone209-237-2703 faxGot ahold of a Trade-a-Plane, and full page ad is on pg.#3 . The ad listsjust about anything you need, parts wise. The "parts and maint. manual"was $17.50, and you can completely rebuild your engine from this. Dated3/'44 but it's new.People at Fresno were very easy to talk to.walt-----------------------------------------------------Click here for Free Video!!
Posted: Fri Mar 31, 2000 9:16 am
Original Posted By: fishin
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 10 Msgs - 03/29/00In a message dated 03/30/2000 1:53:49 AM Central Standard Time, pietenpol-list-digest(at)matronics.com writes:From: "Barry Davis" >Reply-To: pietenpol-list(at)matronics.com >To: "piet list" >Subject: Pietenpol-List: PIET: a-65 to a-75 >Date: Wed, 29 Mar 2000 21:36:51 -0500 > > >Does anyone know the procedure to convert an A-65 to A-75? >Does a manual exist? >Any help at all? > >Barry Davis >bed(at)mindspring.com > >>There is (was) a Continental Service Bulletin that covered this subject. I don't know if it's still available.Ed________________________________________________________________________________Date: Sun, 02 Apr 2000 11:18:15 -0500
Posted: Sun Apr 02, 2000 3:51 pm
Best I can remember it is pistons and valves and maybe an oil hole in theconnecting rod for extra oil spray .Some of this may be for the A80.About aseasy to make A80 as an A75.Bill-----Original Message-----
> > > Does anyone know the procedure to convert an A-65 to A-75?> Does a manual exist?> Any help at all?> > Barry Davis> bed(at)mindspring.com> > > > ________________________________________________________________________________
> Subject: Pietenpol-List: PIET: a-65 to a-75> > > > >> >Does anyone know the procedure to convert an A-65> to A-75?> >Does a manual exist?> >Any help at all?> >> >Barry Davis> >bed(at)mindspring.com> >> >> > >> through>>
http://www.matronics.com/archives>
http://www.matronics.com/emaillists>> Matronics!>> > > > ________________________________________________________________________________
>> Subject: Pietenpol-List: PIET: a-65 to a-75>>>>>> >> >>> >Does anyone know the procedure to convert an A-65>> to A-75?>> >Does a manual exist?>> >Any help at all?>> >>> >Barry Davis>> >bed(at)mindspring.com>> >>> >>>>>>>>> through>>>>
http://www.matronics.com/archives>>
http://www.matronics.com/emaillists>>>> Matronics!>>>>>>>>>>>>________________________________________________________________________________Date: Thu, 30 Mar 2000 15:40:28 -0800 (PST)
Original Posted By:> >> Barry Davis
> Subject: Re: Pietenpol-List: PIET: a-65 to a-75> > > > >> >walt, your right. i looked it up and the only> >difference in th 65 to 90 hp is con rods,> compresion> >ratio and hp quoted at rpm. what was the address of> >that placve in CA? thanks jkc.> >> >--- walter evans wrote:> evans"> >> > >>> >> Barry,> >> I was told that the pistons are different, and> you> >> have to check the> >> connecting rods for an oil hole in the rod> bearing (> >> where it rides on the> >> crank). The newer ones had the hole, I guess,> to> >> take the added pounding.> >> My mentor told me that if you have to replace> >> pistons anyway, go for the> >> 75's. But to throw away good 65 pistons and put> in> >> 75 pistons, that you> >> won't see that much of a difference.> >> I got all my Continental parts from a place in> >> California. Can look up the> >> name. They have a nice parts book covering the> A65> >> and A75. Giving> >> complete dimensional drawings and weights also.> >> Parts were reasonable and> >> all in stock.> >> my two cents> >> walt> >>>>-----------------------------------------------------> >> Click here for Free Video!!> >>
http://www.gohip.com/freevideo/> >>> >> -----Original Message-----
> >> Subject: Pietenpol-List: PIET: a-65 to a-75> >>> >>> Davis"> >> > >> >> >> >Does anyone know the procedure to convert an> A-65> >> to A-75?> >> >Does a manual exist?> >> >Any help at all?> >> >> >> >Barry Davis> >> >bed(at)mindspring.com> >> >> >> >> >>> >>> >>> >> through> >>> >>
http://www.matronics.com/archives> >>
http://www.matronics.com/emaillists> >>> >> Matronics!> >>> >>> >>> >>> >>> >> >> > >> through>>
