Pietenpol-List: props Franklin vs. Continental
Posted: Thu Jun 01, 2000 7:08 am
Can anyone tell me if Franklin and early continental prop flange dimensions are the same. I have a 80 hp Franklin that I'm overhauling for the Peit that I,m building.I saw a photo in the image library of an A-65 and the flange and snout look very similar, I guess what I need is the bolt circle and snout diameters of the A-65. This list is a great thing, I've learned a lot just by reading in on the questions and answers. Thanks-Ed Grentzer Palm Harbor Fl.________________________________________________________________________________Date: Thu, 1 Jun 2000 05:59:10 -0700 (PDT)
RE: Pietenpol-List: props Franklin vs. Continental
Posted: Thu Jun 01, 2000 10:46 am
I had a Franklin 90, and the A-65 does not match.Steve E.-----Original Message-----
Posted: Thu Jun 01, 2000 11:40 am
>From: Steve Eldredge >Reply-To: pietenpol-list(at)matronics.com>To: "'pietenpol-list(at)matronics.com'" >Subject: RE: Pietenpol-List: props Franklin vs. Continental>Date: Thu, 1 Jun 2000 09:46:33 -0600>>>I had a Franklin 90, and the A-65 does not match.>>Steve E.>>-----Original Message----->From: owner-pietenpol-list-server(at)matronics.com>[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of ED>GRENTZER>Sent: Thursday, June 01, 2000 6:09 AM>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: props Franklin vs. Continental>>>>> Can anyone tell me if Franklin and early continental prop flange> dimensions are the same. I have a 80 hp Franklin that I'm overhauling> for the Peit that I,m building.I saw a photo in the image library of> an A-65 and the flange and snout look very similar, I guess what I> need is the bolt circle and snout diameters of the A-65. This list is> a great thing, I've learned a lot just by reading in on the questions> and answers.> Thanks-Ed Grentzer> Palm Harbor Fl.>>>Thanks Steve I guess I'll have to buy a new prop as the chances of finding >a used Franklin prop is probably slim & none. Also SensenichProp company here in Fl. lists a wood prop for the A-65 Pietenpol Iwas kinda hoping I might be able to use one of theirs.Thanks again for the info.>________________________________________________________________________________Date: Thu, 1 Jun 2000 11:22:13 -0600 (MDT)
Posted: Thu Jun 01, 2000 1:19 pm
Original Posted By: dpilot
>From: Ken Beanlands >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: RE: Pietenpol-List: props Franklin vs. Continental>Date: Thu, 1 Jun 2000 11:33:57 -0600 (MDT)>>> > >Thanks Steve I guess I'll have to buy a new prop as the chances of >finding> > >a used Franklin prop is probably slim & none. Also Sensenich> > Prop company here in Fl. lists a wood prop for the A-65 Pietenpol I> > was kinda hoping I might be able to use one of theirs.Thanks again for >the> > info.>>Sensenich can make a wooden porp for the Franklin at about the same price>as the Cont. I had a quote from them for a prop for my Franklin 4A-235>last year. Of course, you will need a crush plate for the front of the>prop if you go with a wooden one, but they can supply that too. Tell them>what engine, max RPM and plane you have as well as the approximate cruise>speed, climb speed and climb rate, and they can come up with an>appropriate custom prop. Since most of thier props are made as needed,>there is no price penalty for a custom one.>>Also, if the classic look is not important, Ivo also makes a hub that will>allow you to mount thier prop to your engine. They use modern-looking>carbon fibre blades (2-6 blades depending on the power) mounted to a hub>that provides easy ground adjustability. They even have an electric,>in-flight adjustable hub that utilizes the same blades. I think thier prop>is around the $700-$800 for a ground adjustable model.>>I ended up with a metal McCaulley Clip-Tip that came with my engine. It>was used and an additional $600 USD. Check out Avweb, Barnstormers and>Wings On-Line for used props.>>Ken Beanlands B.Eng (Aerospace)>Calgary, Alberta, Canada>Christavia MK 1 C-GREN>>>> Thanks for the prop info ken. I didn,t realise Sensenich would custom build a prop as their web site listed props by application. I'll probably go with their wood prop as their shop is only about 30 miles from me. In mean while I'll keep an eye out for a good used one.Thanks again--Ed>>________________________________________________________________________________Date: Thu, 1 Jun 2000 12:23:31 -0700 (PDT)
