Pietenpol-List: Antique mag switch
Posted: Tue Aug 29, 2000 12:25 pm
Original Posted By: "mboynton(at)excite.com
Subject: Pietenpol-List: Antique mag switchAll,I took a look at the picture of the antique mag switch listed on e-bay, butI'm a little confused. The selector has positions for off, battery, mag andboth. So, how do you check the right and left mag independent of eachother, as with modern switches? Or, maybe you don't?Mark BoyntonGilbert, AZSay Bye to Slow Internet!
http://www.home.com/xinbox/signup.html_ ... __________
Re: Pietenpol-List: Antique mag switch
Posted: Tue Aug 29, 2000 5:39 pm
Original Posted By:> mboynton(at)excite.com(InterMail vM.4.01.02.39 201-229-119-122) with
Mark, that switch is for a Jacobs engine, which has one magneto and abattery/distributor system for the dual ignition, so you check the battery,mag, and both.----------
Posted: Tue Aug 29, 2000 6:35 pm
Original Posted By:> > mboynton(at)excite.com(InterMail vM.4.01.02.39 201-229-119-122) with
Subject: Re: Pietenpol-List: Antique mag switchGene,Thanks for the reply. That's what I like about this list - what a resource.Mark> > Mark, that switch is for a Jacobs engine, which has one magneto and a> battery/distributor system for the dual ignition, so you check thebattery,> mag, and both.> > ----------
Posted: Wed Aug 30, 2000 4:40 pm
Posted: Fri Sep 01, 2000 11:40 am
> vM.4.01.02.39 201-229-119-122) with ESMTP for;> > All,> > I took a look at the picture of the antique mag switch listed on e-bay,but> I'm a little confused. The selector has positions for off, battery, magand> both. So, how do you check the right and left mag independent of each> other, as with modern switches? Or, maybe you don't?> > Mark Boynton> Gilbert, AZ> > > Say Bye to Slow Internet!>
http://www.home.com/xinbox/signup.html> > > > ________________________________________________________________________________
Original Posted By: "Daryl Bortel"
> > > vM.4.01.02.39 201-229-119-122) with ESMTP for> ;> > > > All,> > > > I took a look at the picture of the antique mag switch listed on e-bay,> but> > I'm a little confused. The selector has positions for off, battery,mag> and> > both. So, how do you check the right and left mag independent of each> > other, as with modern switches? Or, maybe you don't?> > > > Mark Boynton> > Gilbert, AZ> > > > > > Say Bye to Slow Internet!> >
http://www.home.com/xinbox/signup.html> > > > > > > > > > > > >Say Bye to Slow Internet!
