Pietenpol-List: 4" don't mean squat
Posted: Thu Aug 31, 2000 3:28 pm
Original Posted By: "Greg Yotz"
Subject: Pietenpol-List: 4" don't mean squat On the other hand, there was discussion in the BAPNews once on how acenter section cut out had a drastic effect on performance of the Piet.Could a 4" clip have the same effect? I don"t recall, but I wouldimagine it was a Ford Piet. Probably a combination of the cut out andthe radiator location, the radiator blocking air flow over the centersection. I'm wanting to use a cut out, so am thinking about anunderslung rad. Leon S.________________________________________________________________________________
Re: Pietenpol-List: 4" don't mean squat
Posted: Thu Aug 31, 2000 3:48 pm
Original Posted By: "Daryl Bortel"
The cutout problem was not just loss of lift area but induced drag. Noinduced drag if you just shorten wings. The test aircraft, if I remembercorrectly was also on the heavy side. Always remember..."Build light andfly right..."Greg>> On the other hand, there was discussion in the BAPNews once on how a> center section cut out had a drastic effect on performance of the Piet.> Could a 4" clip have the same effect? I don"t recall, but I would> imagine it was a Ford Piet. Probably a combination of the cut out and> the radiator location, the radiator blocking air flow over the center> section. I'm wanting to use a cut out, so am thinking about an> underslung rad. Leon S.>>________________________________________________________________________________
Posted: Fri Sep 01, 2000 8:14 am
Leon:I am interested in the underslung radiator idea. I am ready ti install my radiator soon I hope. Any ideas would be greatly appreciated.ThanksWalter>From: "Greg Yotz" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Re: Pietenpol-List: 4" don't mean squat>Date: Thu, 31 Aug 2000 15:48:10 -0500>>>The cutout problem was not just loss of lift area but induced drag. No>induced drag if you just shorten wings. The test aircraft, if I remember>correctly was also on the heavy side. Always remember..."Build light and>fly right...">>Greg>> >> > On the other hand, there was discussion in the BAPNews once on how a> > center section cut out had a drastic effect on performance of the Piet.> > Could a 4" clip have the same effect? I don"t recall, but I would> > imagine it was a Ford Piet. Probably a combination of the cut out and> > the radiator location, the radiator blocking air flow over the center> > section. I'm wanting to use a cut out, so am thinking about an> > underslung rad. Leon S.> >> >>>________________________________________________________________________________
