Pietenpol-List: two or three piece wing
Posted: Sat Sep 09, 2000 7:29 pm
Has anyone ever built a two piece wing with the "center section" in one wing and the other wing with only the outer panel? The archives have a msg from David B Schober dated Dec 03, 1998 indicating such an arrangement is simpler to build and lighter. The weight of such a wing setup may be slightly off center but not enough to notice I would surmise. I've about finished my ribs and am trying to decide how to go from here. Anybody with a two-piece wing?? Are you still there David Schober?________________________________________________________________________________
Re: Pietenpol-List: two or three piece wing
Posted: Sat Sep 09, 2000 7:58 pm
Subject: Re: Pietenpol-List: two or three piece wingIn a message dated 9/9/00 5:30:53 PM Pacific Daylight Time, pietenpol41(at)hotmail.com writes:>I have a three piece wing on the first aircamper because of limited space and a one piece wing on the second. My humble opinion is to build one or the other as designed; both are very good. ________________________________________________________________________________
Posted: Sat Sep 09, 2000 8:57 pm
Original Posted By: Borodent(at)aol.com
Subject: Re: Pietenpol-List: two or three piece wing leonstefanhutks(at)webtv.net (Leon Stefan)Hello David: There is a fellow in Collinsville OK. (Tulsa) with a 2piece wing. But I'll be darned If I know his name. The cabines taper tothe center at the wing. It was a steel tube fuselage. I once read (oldissue of the IPA news letter) of a 2 piece wing where the center sectionwas built into one panel and the other panel was joined outboard of thecabine struts te same way a 3 piece wing would be joined to a centersection....strange. I checked the last roster Grant put out, no DavidSchober. Leon S. ________________________________________________________________________________
Posted: Sun Sep 10, 2000 7:54 am
