Pietenpol-List: matronics address
Posted: Fri Nov 03, 2000 7:18 am
Not long ago the fellow who runs this list posted an address to whichwe can send contributions to help support his operations. I accidently erased that E-mail before writing down the address. Can someone please post that physical address so I can send in a check. Thanks Ed "G" Paalm Harbor Fl.________________________________________________________________________________
Re: Pietenpol-List: Newbie question: Rudder Bar versus Pedals
Posted: Fri Nov 03, 2000 7:40 am
>>> > > the consensus was pedals can put a lot of strain on>> > > the rudder horn, enough to break or bend it. It was>> > > the opinion that the rudder bar is the way to go.I have had no problems with the rudder bar. The only mod I did make was tobring the tail wheel cables to the rudder bar rather then swag them to therudder cables as indicated in the prints.Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
Re: Pietenpol-List: rudder pedals
Posted: Fri Nov 03, 2000 7:44 am
Del If you also make the front stick removable and devise a method ofdisconnecting the throttle in the front cockpit, if you have one in mind,then non pilot type passengers will have less to worry about touching,baggagewill not be able to jam the controls we you are AirCamping. ;-)John----- Original Message -----
Re: Pietenpol-List: matronics address
Posted: Fri Nov 03, 2000 9:04 am
ED G. The Matronics contribution address is:c/o Matt DralleMatronicsPO Box 347Livermore, CA 94551 Ed, I deleted mine too, without thinking about it, luckily mine was still in my trash can waiting to be dumped. I was thinking about doign the same and sending in a check. This is a very valuable resource, and worth supporting. I haven't before, but I think I will this year.Thanks!Gary________________________________________________________________________________
Posted: Fri Nov 03, 2000 9:33 am
Original Posted By: Merrill C Isaacson
Subject: Re: Pietenpol-List: matronics addressGary, DittoCorky in La________________________________________________________________________________Date: Fri, 3 Nov 2000 11:08:46 -0500 (EST)
