Pietenpol-List: A65 pipes from VW exhaust
Posted: Thu Jan 11, 2001 2:36 pm
Don't know if this has been discussed before, but in thinking about exhauststacks for my A65, the storebought ones are not cheap. Got these from JCWhitney and they are VW heater bypass pipes. Had made and flown thesepipes on a 1/2 VW U/L . ( 2 for $9.95) They are a 1 1/2" OD pipe shapedlike a candy cane with the exhaust flange welded on . The flange matchesthe A65. Gonna cut and fit to get the layout that is best, then weld.You could go to http://www.jcwhitney.com/ and see them,I guess.If they don't work, the most that I'm out is $20.00 for 4 pipes, and sometime.walt-----------------------------------------------------________________________________________________________________________________
