Pietenpol-List: Re: Pietenpol-List Digest: 4 Msgs - 01/20/01
Posted: Sun Jan 21, 2001 9:47 am
Original Posted By: dralle(at)matronics.com (Matt Dralle)
T-88 (8 oz. or 1/2 pint kits) costs:Rockler - $12.99A S & S - $12.70Wicks - $12.89Direct from System 3 - $14.00The costs per volume is not a linear relationship so the pint kit doesnot cost twice as much, only a little more, and the quart kit isagain, only a little more. I think if you bought empty bottles, itwould still cost you $10 (ha ha).Robert HainesMurphysboro, Illinois________________________________________________________________________________
Posted: Sun Jan 21, 2001 11:18 pm
Dear friends,I am building the steel tube fuselage Pietenpol Aircamper and plan to use the Continental engine.Does anyone have information that they could share with me that would allow me to calculate the C.G. so that I can know how much I may need to lengthen the steel tube fuselage? Also, any thoughts on the idea of adding X more inches of tubing between station 1&2, 14&13 of the supplemental steel tube drawings, in order to arrive at a proper C.G ( I am thinking 4 to 6 but I would like to do the math first )On the top of a drawing dated 3-8-65 D.P. there are a few C.G. calculations for a 1960 corvair engine Aircamper. It showed a calculated C.G. of 16.85 and said that the C.G should not be in excess of 20' aft of DATUM. What is the "optimum" C.G. measurement for such a craft?I fear that if I build according to plans and use the Continental engine, I may end up having to cast my own Lead spinner in order to balance out.Any thoughts?..........Allen Smith________________________________________________________________________________
Posted: Mon Jan 22, 2001 6:31 am
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 4 Msgs - 01/20/01>>>Dear friends,>>I am building the steel tube fuselage Pietenpol Aircamper and plan to use>the Continental engine.>>Does anyone have information that they could share with me that would allow>me to calculate the C.G. so that I can know how much I may need to lengthen>the steel tube fuselage? Also, any thoughts on the idea of adding X more>inches of tubing between station 1&2, 14&13 of the supplemental steel tube>drawings, in order to arrive at a proper C.G ( I am thinking 4 to 6 but I>would like to do the math first )>Your problem ,as I see it, is that there is little steel tube experience outthere.For one thing, the steel tube fuselage is lighter that the wood fuselage,soyou may have less of a CG problem.If the steet tube plans were for a Ford engine & you plan on a 65 cont youare looking at about 80 lbs less engine weight.As suggested, I would plan on moving the wing back, rather than the engineout. Once the engine is fixed, you can't change it, but the wing, you canadjust.Mike B Piet N 687MB ( Mr Sam ) 0-200 Cont________________________________________________________________________________Date: Mon, 22 Jan 2001 12:52:14 -0500
Re: Pietenpol-List: Re: Pietenpol-List Digest: 4 Msgs - 01/20/01
Posted: Mon Jan 22, 2001 6:54 am
allen smith asked:> Also, any thoughts on the idea of adding X more> inches of tubing between station 1&2, 14&13 of the supplemental steel tube> drawings, in order to arrive at a proper C.G ( I am thinking 4 to 6 butI> would like to do the math first )No doubt you know this already, but just in case:The usual technique is just to move the wing back -- shift the datum line,rather than the cg. One local builder who used a C-85 found it necessaryto move the wing about 4 inches, if my memory is working for once. Thismeant making up a new set of cabanes and front bracing, as the originalsdid not have enough adjustment capacity. Worked out well, though.Owen Davies________________________________________________________________________________
Posted: Mon Jan 22, 2001 11:03 am
Original Posted By: allen smith
-----Original Message-----
