Pietenpol-List: offset
Posted: Wed Mar 14, 2001 2:20 pm
Concerning the vertical fin offset... Don't you have an option of eitherbuilding in a fin offset or by building an offset into the motor mount? Ithought that the plans detail a thrust angle down and to one side in themount and leave the vstab true.Joe KrzesSpring, TX>The down thrust should be incorporated as per plans. In my opinion, theright thrust angle will depend on the engine.In my case, ( 0-200), aright angle is required.I offset the fin with a few washers under the right angle bracket. AfterI flew the airplane for a while, I added a tab to the rudder.Mike B ( Piet N687Mb ( Mr Sam )________________________________________________________________________________
