Pietenpol-List: Drilling---off center?
Posted: Mon Apr 02, 2001 10:57 am
Mike,I read your description of the drilling of the fittings and I'm confused; "I start the hole straight in and then rotate the tubing to where the angle is correct and then finish drilling. The started hole will be able to hold the drill in place."We have finished our landing gear and have the fuselage up on the gearand didn't go about it that way. The plans show a much simpler way todrill the holes and they come out easily and quickly.Cut the fittings to the required length and deburr, place in a "vee" blockand set on end, mark the 1/8" offset with a centerpunch and drill the1/4" hole. No angle drilling required or needed. The "vee" block safelyholds the fitting straight up for drilling.Then, as the plans call out, file the flat to an approximate angle, settingthefitting on the plate, to which it will be welded later, which is placed ontheupside down fuselage at the proper locations. Insert a long 1/4" rod toconnect the forward and rear bushings, being careful of sag in the rod, andcheck how much fileing of the angled flat is needed.Then as described by a previous lister, align, mark, clamp and tack weldthe fitting to the plate and adjust as required using a drill rod insertedinboth forward and rear bushing/plates for alignment and finish welding. Ofcourse, do the welding off the fuselage, no need to set fire to thestructurein the excitement of the moment.Rodger ChildsPiet in progress________________________________________________________________________________
