Pietenpol-List: A Engine Specs
Posted: Mon Apr 09, 2001 5:24 pm
Subject: Pietenpol-List: A Engine SpecsPieters,Found this in some of my father's old files. Thought maybe someone might use some of this info. If you know it just disregardClearance Limits for assembly of "A" Engines.(Ford service bulletin, June 1931) All dimensions in inches.Piston in cylinders-- .002 maximumPiston ring gap, lower ring-- .008 to .010Piston ring gap, centerring-- .010 to .012Piston ring gap, upper ring-- .012 to .015Ring groove clearance-- .001Piston pin fit in connecting rod bushing--- .0003 maxPin in piston-- .0002 to .0005 shrink fitPistons assembled with split side toward left side of engine.Connecting rod side play on crankshaft-- .008 to .012Connecting rod clearance between piston bosses-- .040 to .053Connecting rod clearance on crankshaft diameter-- .001Connecting rods assembled with oil dips toward camshaftCrankshaft end play-- .002 to .004Main bearing clearance-- .001Camshaft bearing clearance --.003 maxCamshaft end play taken upby tention of spring in front cover. Spring tension 35 lbsValves to push rods clearance-- .010 to .013Exhaust valves in valve guides -- .002Intake valves in valve guides -- .001 to .0015Valve lift -- .287Push rod clearance --.0015Timing gear backlash -- .004End play of water pump shaft -- .006 to .010Spark plug gap -- .035Hope this might help someone.Corky in ole ford country________________________________________________________________________________Date: Thu, 12 Apr 2001 08:24:50 -0700 (PDT)
