Pietenpol-List: re-hinges
Posted: Sat Apr 21, 2001 6:18 am
Thanks to Jerry and Doug for the advice. I should be able to source some suitable high tensile machine screws locally. It sure feels good to have made a start.cheers Rod W.West Aussie________________________________________________________________________________
Pietenpol-List: News letter reprints:
Posted: Sat Apr 21, 2001 6:47 am
Original Posted By: kgardner(at)odu.edu
Subject: Pietenpol-List: News letter reprints:Great job Mike. Thanks a lot. Leon S. InKansas with head down in shame. My Piet is being built with a shop fullof Chinese made tools.________________________________________________________________________________
Re: Pietenpol-List: re-hinges
Posted: Sat Apr 21, 2001 7:53 pm
Subject: Re: Pietenpol-List: re-hingesIn a message dated 4/21/01 7:20:06 AM Eastern Daylight Time, rodwooller(at)hotmail.com writes:>Are you using locally obtained wood ? Are you to the stage of building ribs yet ?________________________________________________________________________________
Posted: Sun Apr 22, 2001 2:57 am
Original Posted By: "Neal Hinson"
I am using Douglas Fir (known as Oregon over here)as spruce is impossible to find in Western Australia.Wing ribs are a long way off as I intend to finish the tail feathers first and then make a start on the fuselage.When it comes to the spars and ribs I will probably get some Hoop Pine sent over from Queensland.Rod W.>From: Dmott9(at)aol.com>Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: re-hinges>Date: Sat, 21 Apr 2001 20:53:21 EDT>>>In a message dated 4/21/01 7:20:06 AM Eastern Daylight Time,>rodwooller(at)hotmail.com writes:>> suitable high tensile machine screws locally. It sure feels good to have> made a start.>> cheers Rod W.> West Aussie> >>>>Are you using locally obtained wood ? Are you to the stage of building >ribs>yet ?>>________________________________________________________________________________
Posted: Sun Apr 22, 2001 9:16 pm
Original Posted By: "oil can"
Subject: Re: Pietenpol-List: re-hingesIn a message dated 4/22/2001 12:59:43 AM Pacific Daylight Time, rodwooller(at)hotmail.com writes:> When it comes to the spars and ribs I will probably get some Hoop Pine sent > over from Queensland.> Hi Rod,My Piet is 100% Douglas Fir, except for Mahogany Marine plywood where ply is called out. Doug Fir will make beautiful spars and ribs. I have all the ribs done, wing center section, all spars, all tail surfaces, and fuselage all framed including seats.All I am working on now is the fittings (steel Work). Cheers, Jim________________________________________________________________________________
