Pietenpol-List: Corvair / short fuse C.G.
Posted: Sat Apr 28, 2001 4:32 pm
Original Posted By: Don Mosher
Re: Pietenpol-List: Corvair / short fuse C.G.
Posted: Mon Apr 30, 2001 9:38 am
04/30/2001 10:38:41 AMEd,As previously stated, Wm. Wynn's corvair weighs about 205lbs. without theelectric starter.He has it on a 1933, short-fuse plane & extended his motor mount 6" to getthe right w&b.With the lighter Franklin, I suspect you would need to go a little longer&/or move the wing back.Andrew Pietenpol is putting a Franklin 80 in the new Piet he is building,but I don't recallwhich fuse he is doing, I think it is the longer, corvair-mount version.Hope this helps.Cheers!________________________________________________________________________________Date: Mon, 30 Apr 2001 14:34:36 -0400
