Pietenpol-List: building the fuselage
Posted: Sat Apr 28, 2001 7:46 pm
Hey guys, What is the most common way of building the fuselage considering that the gussets are one the inside? Do you build the right side first with the gussets glued on top of the joints, then for the left side just make butt joints and add the gussets to the inside after the left side frame has been lifted off the building table? I know I could glue the plywood side to the outside of the left frame while it is in the jig but I would rather do that after the fuselage is together and attached at the tail post (because part of the plywood extends aft enough to where the fuselage starts to come together). Corky, hope you get back to speed soon. Is there any association between the need for your heart surgery and the special ingredient you add to your shrimp dish? Jeff in Texas cheering for the Toronto Maple Leafs________________________________________________________________________________
Re: Pietenpol-List: building the fuselage
Posted: Sat Apr 28, 2001 8:01 pm
Subject: Re: Pietenpol-List: building the fuselageJeff,Guess I should have been eating like a yankee instead of like a king in La. Isabelle, my bride, from Mattoon, Ill has taken over the family food planning. No more homemade bread, butter, bacon, pork sausage, eggs, homo milk, bisquits w/ real butter, syrup, waffles, hot cakes. Tonight we did have a southern delight, black eyed peas. Tomorrow I'll try to get her to buy me some turnip and mustard greens but no sow-belly for seasoning. Fraid it's going to be slim pickins down south. Probably try to feed me those yankee delights such as bread and rice puddings, rubbards or whatever those people eat. Can you imagine I'll have no more rice and gravy, shrimp creole, crawfish bisque. HORROWSCorky in pure food La________________________________________________________________________________
-- Pietenpol-List message posted by: Isablcorky(at)aol.com Jeff, Guess I should have been eating like a yankee instead of like a king in La. Isabelle, my bride, from Mattoon, Ill has taken over the family food planning. No more homemade bread, butter, bacon, pork sausage, eggs, homo milk, bisquits w/ real butter, syrup, waffles, hot cakes. Tonight we did have a southern delight, black eyed peas. Tomorrow I'll try to get her to buy me some turnip and mustard greens but no sow-belly for seasoning. Fraid it's going to be slim pickins down south. Probably try to feed me those yankee delights such as bread and rice puddings, rubbards or whatever those people eat. Can you imagine I'll have no more rice and gravy, shrimp creole, crawfish bisque. HORROWS Corky in pure food La ________________________________________________________________________________
Posted: Sat Apr 28, 2001 8:53 pm
Original Posted By: "Mckellars"
Subject: Re: Pietenpol-List: building the fuselageIn a message dated 4/28/01 5:47:52 PM Pacific Daylight Time, jeff2dogs(at)hotmail.com writes:> What is the most common way of building the fuselage considering that > the gussets are one the inside? Do you build the right side first with the > gussets glued on top of the joints, then for the left side just make butt > joints and add the gussets to the inside after the left side frame has been > lifted off the building table? I know I could glue the plywood side to the > outside of the left frame while it is in the jig but I would rather do that > after the fuselage is together and attached at the tail post (because part > of the plywood extends aft enough to where the fuselage starts to come > Jeff,I build the right side first with the small gussets then remove it from the ji and put the small gussets on the other side. Next, mark the strut locations onto both side sheets, then glue the side sheet on the right side out of the jig. Then build the left side putting the side sheet on in the jig and the small gussets every where else, remove from the jig and put the rest of the small gussets out side of the jig. There is a good explanation of this process in the 1933 F&GM sky scout plans. Doug Bryant Wichita Ks________________________________________________________________________________
Posted: Tue May 01, 2001 8:51 am
