Pietenpol-List: Horizontal Stabilizer
Posted: Wed May 09, 2001 5:08 am
I have just laid up my horizontal stabilizer in the jig and was measuring out where the elevator hinges would attach when I find that the diagonal braces end up just where the outside hinges should go (4" from the end). I can get one machine screw thru the beam, but the outer one should go where the brace ends. I have some 1 3/4" stainless wood screws that I was thinking of screwing thru the beam and brace with a bit of help from T88 epoxy. Is this an acceptable practice, or is there another way of fixing the outer hinge?Rod W.in sunny West Aussie.________________________________________________________________________________Date: Wed, 9 May 2001 08:46:38 -0400 (EDT)
Re: Pietenpol-List: Horizontal Stabilizer
Posted: Wed May 09, 2001 10:47 am
Hi Rod, I'm not sure about your particular hinge location, we all build a little differently, but I plan to use one of the single-eared nutplates for that outer nut. I'm thinking I'll rivet the nutplate to a longer piece of aluminum, and use that to anchor to the wood. I've also thought about just moving the whole hinge inward an inch or two to provide clearance. I'd like that hinge as far out as possible, but I don't think an inch or two is gonna make or break it!! Those are just a couple of thoughts. I saved all that hard work and just went to the fuselage.... I've got several cleanup jobs to do like that before the tailfeathers are fully finished!Good luck!Gary MeadowsSpring, Texas________________________________________________________________________________
Posted: Wed May 09, 2001 11:17 am
Subject: Re: Pietenpol-List: Horizontal StabilizerIn a message dated 05/09/2001 6:10:28 AM Eastern Daylight Time, rodwooller(at)hotmail.com writes:>Take a look at Mike Cuy's picture site:
http://aircamper.no-ip.com/acimgor this one of Horizontal Stab:
http://aircamper.no-ip.com/acimg/em-horiz1.jpgLOTS of good construction pictures of various airplanes.________________________________________________________________________________Date: Wed, 09 May 2001 11:15:47 -0600
Posted: Wed May 09, 2001 10:54 pm
Original Posted By: TomTravis(at)aol.com
Rod Wooller wrote:> I have just laid up my horizontal stabilizer in the jig and was measuring> out where the elevator hinges would attach when I find that the diagonal> braces end up just where the outside hinges should go (4" from the end). I> can get one machine screw thru the beam, but the outer one should go where> the brace ends. I have some 1 3/4" stainless wood screws that I wasthinking> of screwing thru the beam and brace with a bit of help from T88 epoxy. Is> this an acceptable practice, or is there another way of fixing the outer> hinge?>> Rod W.> in sunny West Aussie.Well Rod,That was one of the first parts we worked on on our Piet project some7 years ago and we drilled the outer attachment hole clear thru thediagonal brace, saw where it came thru and cut and glued a triangularblock in to have a flat surface for the flat washer and locking nut to sit.When the glue was dry, we drilled thru the diagonal block.Now all this means that the nut is down inside the gussets and the flatheadscrew is longer than normally you would be accustomed to seeing it but itworks for us.Keep in mind that for fitting up to see how things fit, use a regular nutbecause all the hardware will have to be removed so that you can varnishthe wood every where, including down in the gussets and also in the drilledholes. Of course this means you'll have to drill out the holes again toremovethe excess varnish.Rodgerstill building, but much closer________________________________________________________________________________
Posted: Sun Sep 23, 2001 12:05 am
Original Posted By: flyboy_120(at)webtv.net (Ed G.)
I just finished all the parts of my tail section, and am putting themtogether for the first time. When I built them, I made sure that all of themain parts of the horizontal stabilizer were on the same center line- theleading edge, center beam, and rear main beam. I used 3/16 plywood in thecenter on the leading edge and center beam where the fin attaches, and 1/8ply on the main beam as shown on the plans. I also have 1/8 ply gusset onthe fuselage over the tailpost.Using this combination, as the plans show, I need to put a 1/8 ply spacerunder the front edge of the horizontal stab to make it level. And I need toshim up the front 3/16 ply piece on the H-stab and on the rear with a 1/8ply spacer to make the fin sit flush and level with the tailpost.Did I do something wrong? As it stands now, the fin sits high on the 3/16ply piece on the center beam of the H-stab if I don't use spacers.Thanks for the help,Al Swanson________________________________________________________________________________
Posted: Sun Sep 23, 2001 6:34 am
Subject: Re: Pietenpol-List: Horizontal StabilizerAl my horizontal stab came out the same way. If you look at thethicknesses of the members and the spacers called for in the plans itdoesn't add up, I put the 3/16 spacer under the center beam so that thestab. sits parallel to the longerons and then filled in te space underthe leading edge . It took a hair over 1/4" spacer. Ed G. ________________________________________________________________________________
Posted: Sun Sep 23, 2001 7:05 am
Subject: Re: Pietenpol-List: Horizontal StabilizerAl actually a 1/8" spacer under the center beam would give zero degreesof incedence. I may change mine before it's all over, When I did mine Ifigured a little positive incedence wouldn't hurt, Any comments from thegroup on this Ed G. ________________________________________________________________________________Date: Mon, 24 Sep 2001 10:34:43 -0400
Posted: Mon Sep 24, 2001 8:12 pm
Subject: Re: Pietenpol-List: Horizontal StabilizerIn a message dated 9/22/01 10:06:56 PM Pacific Daylight Time, swans071(at)tc.umn.edu writes:> I just finished all the parts of my tail section, and am putting them> together for the first time. When I built them, I made sure that all of the> main parts of the horizontal stabilizer were on the same center line- the> leading edge, center beam, and rear main beam. I used 3/16 plywood in the> center on the leading edge and center beam where the fin attaches, and 1/8> ply on the main beam as shown on the plans. I also have 1/8 ply gusset on> the fuselage over the tailpost.> > Using this combination, as the plans show, I need to put a 1/8 ply spacer> under the front edge of the horizontal stab to make it level. And I need to> shim up the front 3/16 ply piece on the H-stab and on the rear with a 1/8> ply spacer to make the fin sit flush and level with the tailpost.> > Did I do something wrong? As it stands now, the fin sits high on the 3/16> ply piece on the center beam of the H-stab if I don't use spacers.> > Thanks for the help,> > Al Swanson> > > Al,Shimming is fine and is probably considered normal construction technique as any plans can only contain so much detail information. Doug Bryant Wichita Ks ________________________________________________________________________________-Date: Mon, 24 Sep 2001 22:47:23 -0500
Posted: Mon May 06, 2002 1:00 am
Subject: Pietenpol-List: Horizontal StabilizerIn a message dated 5/5/02 9:43:14 PM Central Daylight Time, Borodent(at)aol.com writes:>Henry,Yes, the horizontal stabilizer was parallel to the top longerons, just as it calls for in the plans. This part is kind of a guessing game. Tweek the turnbuckles about a half turn at a time, to pull the L.E. of the stab down and relieve some of the back pressure needed on the stick, and go fly. A little bit goes a long way in flight. If you stand back, and eyeball it, you can barely notice it. I'm going to adjust it down again, before the next flight. I'm ready to Kick the tires, twang the wires, and light the fires !!! Chuck GantzerNX770CG________________________________________________________________________________Date: Mon, 06 May 2002 08:14:24 -0500
