Pietenpol-List: Needle little help
Posted: Fri May 11, 2001 12:48 pm
Original Posted By: "pierson's"
Subject: Pietenpol-List: Needle little helpDear Pieters,Have had a great day making up all my elevator cables and fabing the little fairleads in some neutral spot so the cables will not wander inches through the fabric. What should this tensions on those elvator cable compare to and should they be equal tensioned. Boy, I sure could use some help today.Corky wandering around in "Sportsman Paradise".________________________________________________________________________________
Re: Pietenpol-List: Needle little help
Posted: Fri May 11, 2001 5:21 pm
Subject: Re: Pietenpol-List: Needle little helpIn a message dated 5/11/01 10:50:10 AM Pacific Daylight Time, Isablcorky(at)aol.com writes:> Have had a great day making up all my elevator cables and fabing the little > fairleads in some neutral spot so the cables will not wander inches through > the fabric. What should this tensions on those elvator cable compare to and > should they be equal tensioned. Boy, I sure could use some help today.> Corky wandering around in "Sportsman Paradise".> > > Corky,I make them just tight enough to not bind anywhere in the full range of travel. I turns out to be not very tight on any of the flight control cables; certainly not rigged as a modern airplane is. Flies well that way. Doug Bryant Wichita Ks ________________________________________________________________________________
