Pietenpol-List: Stainless steel
Posted: Fri Jun 01, 2001 4:47 pm
Subject: Pietenpol-List: Stainless steelKip: Go with 4130 if you are worried about corrosion. BHP used mildsteel, but 4130 is much stronger and more corrosion resistant.PS. To the new lister Mpls: Del said "forget the F&G plans, theimproved plans are HARD enough" If I can put a word in Del's mouth: "theimproved plans are BAD enough" Get Mike Cuy's tape and take note thatwhen he says most all of the fittings could stand to be a little longerfor bolt clearance. Leon S. Bi$#@ing about the plans in KS.________________________________________________________________________________
