Pietenpol-List: contol cables
Posted: Mon Jun 18, 2001 2:42 pm
Pietenpol-List message posted by: javier cruz HI FRIENDSWELL, I NEED SOME HELP ON THE ELEVATOR CONTROL CABLES:THIS IS THE PROBLEM:THE CABLES ARE ADJUSTED WITH THE CONTROL TUBE SET ONNEUTRAL (0 DEGREES), AND THE TORQUE TUBE SAME ( 0DEGREES) THE CABLES ARE AT 30 POUNDS OF TENSION(RECOMENDED BY A AVIATION MECHANIC), WHEN I MOVE THECONTROL TUBE 20 DEGREES NOSE UP OR NOSE DOWN THECABLES LOSE THE TENSION , BECOME LOOSE TOO MUCH,------------------------I don"t know about that 30 lbs. I don't know what the tension on mycontrol cables is, I adjusted the turnbuckles until the cables worked.MikeB Piet N687MB ( Mr Sam )________________________________________________________________________________
