Pietenpol-List: Re: C65 broken ring
Posted: Fri Sep 07, 2001 10:07 pm
Original Posted By: Craig Lawler
Subject: Re: Pietenpol-List: proper to post pics?>>I don't allow direct posting of enclosures to the Lists because of the>danger of spreading computer v*ruses to so many people. I do offer a free>FTP archive for photos, however. Simply email your photos to:>> pictures(at)matronics.com>>and include a description message that I will forward on to the List with>the URLs of the pictures. For example, in your case Chris, simple send>your email message below to the email address above instead of the List. I>will upload each of the photos to the Matronics FTP server, then forward>your text message to the List with the FTP links for each photo included.>>Best regards,>>Matt Dralle>Matronics Email List Admin.>>=================>>At 12:31 AM 9/8/01 Saturday, you wrote:>>>>>>Attached are some general pictures as to how far along I am>>>>Photograph One: Wing ribs. I have a detailed how I built it picture of>>the jig if you want. and description of how I build the ribs (no nails or>>staples)>>>>Photograph two: Is my tail section (and my table saw). I have a cool way>>of cutting the recesses for the Vi Capler hinges. Worked out perfect>>every time (Famous last words but honestly it did). I did not use any>>nails building the tail>>>>Photograph three: Is a side view of the fuselage. I am working on the>>turtle deck formers right now. I did not put the sides on yet. I have>>some construction pictures as well.>>>>Photograph four: The template I used to get the back lined up.>>>>Photograph five: The back seat>>>>Photograph six: I made a baggage door in the head rest and the seat back>>folds down>>>>Photograph seven: I made the seat back double thick and made the notch>>to KEY it into the side. Hopefully it will work. I can take better>>pictures.>>>>Any thing in particular you want to see? I can photograph it if I have>>gotten that far. I can also scan in some of my HOW I BUILT THIS PART>>pictures as well.>>>>Chris>>Sacramento, CA>>>>>>>Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551>925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email>http://www.matronics.com/ WWW | Featuring Products For Aircraft>> Great minds discuss ideas,> Average minds discuss events,> Small minds discuss people...>>________________________________________________________________________________Date: Sat, 08 Sep 2001 21:31:12 -0400Subject: Pietenpol-List: Re: C65 broken ring
Posted: Sat Sep 08, 2001 8:31 pm
Posted: Mon Sep 10, 2001 8:13 am
Re: Pietenpol-List: Engine suggestions for Piet
Posted: Mon Sep 10, 2001 9:43 am
----- I recently picked up a Pietenpol on ebay (http://cgi.ebay.com/aw-cgi/eBayISAPI.dl ... 1625257429 ) . It's missing the engine motormount and cowling. I originallyplanned on using a converted Corvair engine but have recently come accross a used Continental A65. The seller describes the A65 as having 250 hrs SMOH.Any thoughts out there on how these two engines compair? I'm also looking for alternatives for a cowling. I have no experiencewith fiberglass so I'd like to avoing building one from scratch. Wouldsomething like a J3 cowling fit the Piet?-------------------------------- I looked at your pictures.It appears that you bought a rag wing Pietreplica & not a Pietenpol aircamper. For the engine installation Isuggest that you contact the kit manufacturer. Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________Date: Mon, 10 Sep 2001 10:18:04 -0500Subject: Re: Pietenpol-List: Engine suggestions for Piet
Posted: Mon Sep 10, 2001 10:40 am
Posted: Mon Sep 10, 2001 12:01 pm
Posted: Mon Sep 10, 2001 4:51 pm
Original Posted By: Tim
Subject: Re: Pietenpol-List: Engine suggestions for PietSince you apparently have the ultra-light version of the AirCamper, you might consider using a 1/2 VW conversion. Several are available, listed in Sport Aviation and the Experimenter. Just another option....good luck. Don Cooley________________________________________________________________________________Date: Mon, 10 Sep 2001 17:21:26 -0500
Posted: Mon Sep 10, 2001 10:09 pm
I'm in the midst of building a Half VW for another project. Great engine,especially if you can contact Len Bechtold at Team-38 (believe it'steam-38.com) and get two of his Mosler VW heads/cylinders. Mine is half ofa 2165 cc, 82 HP engine, so it'll be 1182 cc, about 42-45 HP. There's a bitless friction loss with the 1/2. Weight is about 82 lb. installed.Craig----- Original Message -----
