Pietenpol-List: Corvair mount CG
Posted: Thu Sep 20, 2001 3:33 pm
Subject: Pietenpol-List: Corvair mount CGHi everyone .... Can someone answer two questions for me that will helpme figure where the CG of my Franklin needs to be in reference to myCorvair style mount. My Franklin's mount bolt pattern is 2" longer thanthe Corvair pattern and the CG of the engine seems to be centered overthe bolt pattern . So1. Is the Corvair engine centered over it's mounting bolt pattern or isthe pattern centered under one end or the other of the engine??2. What is the distance from the front mount bolt of the Corvair engineto the prop flange? I need to build an extended mount but I can't do that unless I knowthe approximate CG location of the corvair set up. Also does anyone have any updated info on William Wynns condition?? I'm really stuck without knowing how the Corvair sits on the mount.I need to figure the aproximate CG of the Corvairengine and then extend the mount enough to put the Franklins CG outanother 3 to 4inches unless someone knows a better way of doing it. Thanks Ed G.________________________________________________________________________________
Re: Pietenpol-List: Corvair mount CG
Posted: Thu Sep 20, 2001 4:09 pm
Original Posted By: "Ed G."
What Model Franklin?Cy Galley, TC - Chair, Emergency Aircraft Repair, OshkoshEditor, EAA Safety Programscgalley(at)qcbc.org or experimenter(at)eaa.org----- Original Message -----
Posted: Thu Sep 20, 2001 4:16 pm
Original Posted By: "Michael Conkling"
Subject: Re: Pietenpol-List: Corvair mount CG4AC-176-F3 80 hp Franklin. I plan to run it without it's starter andgenerator. I just did the math using the model A s approx.CG and came up with moving the Franklin's CG forward 6" but I guessI"ll go 4" and move the wing back too. Ed G.________________________________________________________________________________
Re: Pietenpol-List: 65 Cont. vs. others ?
Posted: Thu Sep 20, 2001 4:35 pm
Any one run across recent info on Larry Harrison & his Iron Duke poweredPiets (I think he built both the "Poplar Piet" & a Sky Scout) ??Same engine as the S-10 pickup, etc. -- 151 cu. in. L-4 G.M./ Pontiacengine. The first info I found was in BPA #60Michael, thanks for the quick turn around on the copy of your video -- onlyabout 1/2 way thru it (after it arrived yesterday!) -- haven't had 2 1/2 hrsto watch it at one sitting! ;-)Otherwise, I'm having fun soaking upper rib capstrips in the bathtub &cleaning off a work bench for making tail feathers.MikePretty Prairie, KS----- Original Message -----
