Pietenpol-List: alternative spars- UK
Warren wrote:>Go to:>http://www.flyerworld.com/shenty/ukairc ... g2.htm>and scroll down 5 pictures to see a photo of a full set of left>and right spars.Well worth the look-see. I downloaded the photo so I could bring it into a paintshop program and zoom in for more detail. Notice that the builder is using the cam-block technique to hold things in place. You cut circles out of wood (or use pieces left over from cutting holes in wood), drill mounting holes a little off-center, and screw them to your building table. The cam action lets you twist in to hold a part, then twist out to release it. Quick and easy.And while looking at the picture, I started seeing some similarities between these spars and some composite spars I'm designing for my Flying Squirrel. Take a look, at http://www.flysquirrel.net/spar02.jpgOscar ZunigaMedford, Oregonmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
